I bought a [pre-configured MAME PC] from 2huwman recently. It's a great little system and I wanted to mount it to something to protect it a little so I decided to make an enclosure for it.
This is the PC:
Finished enclosure:
4mm routered, drilled, tapped and polished acrylic top and bottom. I added some lugs to hang the enclosure from in the cab from the hooks pictured. I use the same hooks to hang PCBs from.
10mm cut, drilled, tapped and polished solid stainless steel spacers used along with nylon washers. Rubber feet fitted to bottom.
DC jack mounted in the top along with a red momentary power button and a black latching button which turns the audio amplifier on/off. I added this as I have a stereo amp in my E2 so I use the output from the 3.5mm jack rather than via the JPAC.
This is the PC:
Finished enclosure:
