MostroVeneno
Hi!
I´ve recentrly aquired a faulty cps3 board and i was wondering if could be revived.
One thing i noticed is this chip between the white plastic cover, the cart and a chip labeled with capcom and other info.
It reads next to it in white over the pcb "12F HA161031FPJ".
Zooming in, has a pin which is cut (the number 4 from bottom to top, in reference pic attached). I wonder if could be part of the problem. I have not tested the pcb yet, and i´m sending the cart over to mitsurugi to replace bios.
Then i will be able to do further testing. If anyone can check on the pcb if this is a common thing or not i would apreciate. I´ve searched for cps3 schematics to see whats the main purpose of that chip but had no luck.
I attach the pic I took, little blurry though.
