Pinned Sega System 24 multi kit sale & support
    • Sega System 24 multi kit sale & support
      Important information:
      Games aren't preloaded in the multi, users must download romsets by themselves then generate appropriate rom files with the tool (for Windows) provided here in attachment:
      Can't attach file, there's a bug on the forums, max allowed file is 1Mb, file is 970kB still it's rejected on size basis...
      I've uploaded it on filedropper for now but it will disappear within few days:
      http://www.filedropper.com/s24romgen
      Here is the list of romsets that must be used:
      - Bonanza Bros => bnzabros
      - Crack Down => crkdown
      - Dynamic Country Club => dcclubfd
      - Gain Ground => gground
      - Hot Rod => hotrod/hotroda/hotrodj (all 3 needed)
      - Tokoro San no MahMahjan => mahmajn
      - Tokoro San no MahMahjan 2 => mahmajn2
      - Quiz Ghost Hunter => qgh
      - Quiz Rouka ni Tattenasai => qrouka
      - Quiz Syukudai wo Wasuremashita => qsww
      - Quiz Mekurumeku Story => quizmeku
      - Rough Racer => roughrac
      - Jumbo Ozaki Super Masters Golf => sgmast
      - Scramble Spirits => sspirits
      Steps:
      1) Unzip all romsets at the same place
      2) Unzip the S24_ROM_GEN file attached, it contains:
      - ips files for ROMs 01/02/05
      - ips files for floppy images DSKA0000/DSKA0001/DSKA0002/DSKA0003/DSKA0006/DSKA0007/DSKA0009
      - S24_ROM_GEN command file
      - interleave.exe
      - flips.exe
      - hxcfe.exe/libhxcfe.dll/libusbhxcfe.dll (© Jean-François Del Nero)
      3) Simply run the S24_ROM_GEN command file. It will generate ready to burn files for ROMs 01 to 06 and files to be put on an USB stick for floppy based games (copy only the CONTENT of the USB folder to the root of any USB stick formatted in FAT with a minimum size of 64Mb, USB stick provided with the kit is already properly formatted).
      Rom files must be exactly 4096kB except for ROM 01 where you have the choice to burn it in a 27C160 EPROM (2048kB) or 27C322 (4096kB) with a doubled file.
      1) (Long) Introduction
      This System uses either floppies or romboards to load games or both for Bonanza Bros.
      It's not JAMMA but a System 16 to JAMMA adapter works fine.
      It's mid-res, thus 24kHz.
      The multi kit allows to play all floppy based games, included encrypted ones which I have decrypted, from a floppy emulator device.
      Romboard based games are supported on a daughterboard that plugs in any romboard, whatever the security chip installed (but one must be present as it's also used for bank switching). Romboard based games have been patched to circumvent the protection.
      Supported games from the floppy emulator:
      - Bonanza Bros (W), patched - requires a romboard too
      - Crack Down (W), decrypted
      - Dynamic Country Club (U), decrypted
      - Gain Ground (W), decrypted
      - Hot Rod (Turbo 3P, W, set 2) - requires analog I/O board to boot
      - Hot Rod (4P, J, rev C) - requires analog I/O board to boot
      - Quiz Syukudai wo Wasuremashita (J), decrypted
      - Rough Racer (J), decrypted - requires analog I/O board to boot
      - Scramble Spirits (W)
      -Jumbo Ozaki Super Masters Golf (W), decrypted
      Supported games from the romboard:
      - Bonanza Bros, patched - requires the floppy controller too
      - Quiz Ghost Hunter, patched
      - Quiz Mekurumeku Story, patched
      - Quiz Rouka ni Tattenasai, patched - requires 3/4p I/O board to boot
      - Tokoro San no MahMahjan, patched
      - Tokoro San no MahMahjan 2, patched
      - Dynamic Country Club (W), patched
      To enjoy the whole library you need:
      - A motherboard with a standard 68000 CPU installed for the second CPU, if the FD1094 is installed like in the picture below, pull it and install a standart 68000 CPU (original one is rated 10Mhz)
      - a floppy controller (plugs underneath the motherboard), with cables of course (data and power):
      - a romboard (plugs on top of the motherboard):
      - Also some games require extra hardware for controls:
      * 834-6510 analog I/O board for Hot Rod and Rough Racer
      * 3/4p I/O board (plugs on the smaller connector of the motherboard just like on System 18 or 32) for Quiz Rouka ni Tattenasai
      * and probably some specific hardware for the mah-jong games
      With a motherboard and the floppy controller you can play:
      With a motherboard and a romboard you can play:
      With a motherboard, a floppy controller and a romboard you can play all listed games above plus Bonanza Bros.
      2) How to install
      The kit is composed of:
      - a USB floppy emulator with upgraded firmware
      - a USB stick
      - a small board that plugs in the motherboard
      - a bigger board that plugs in the romboard or a complete custom romboard
      - jumper cables to interconnect the 2 boards from the kit
      To install the small board on the motherboard first pull IC1 and IC2, then install the board like this (better pics to come):
      The bigger board plugs in the romboard like this, again all ROMs have to be pulled first.
      Jumpers have to be set like this:
      - J2/J3/J7/J9 = closed
      - J1/J4/J5/J6/J8 = open
      - J10/J11 = 1-2
      If you instead requested a custom romboard with your kit just plug it on the CN2 connector of the motherboard where original romboards plug. There are no jumpers on the custom romboard (everything is already hardwired properly).
      Boards interconnection is simple, left pin with left pin, middle pin with middle pin and... right pin with right pin. You can't damage anything if you do it wrong but games won't boot.
      The USB floppy emulator plugs in place of the original floppy drive.
      Dipswitches allow to select game loader:
      DIP 1/2/3 ---- loader
      000 ---- Dynamic Country Club (rom based)
      100 ---- Hot Rod (floppy)
      010 ---- Quiz Ghost Hunter (rom based)
      110 ---- Tokoro San no MahMahjan (rom based)
      001 ---- Tokoro San no MahMahjan 2 (rom based)
      101 ---- Quiz Mekurumeku Story (rom based)
      011 ---- Quiz Rouka ni Tattenasai (rom based)
      111 ---- All floppy based games except Hot Rod
      Floppy image selection is made by using the two buttons on the front panel of the floppy emulator (-/+), segment display shows selected image (3 digit number), you have few seconds to change image on boot up (3s maybe?):
      - 000 = Bonanza Bros (W)
      - 001 = Crack Down (W)
      - 002 = Dynamic Country Club (U)
      - 003 = Gain Ground (W)
      - 004 = Hot Rod (Turbo 3P, W, set 2)
      - 005 = Hot Rod (4P, J, rev C)
      - 006 = Quiz Syukudai wo Wasuremashita (J)
      - 007 = Rough Racer (J)
      - 008 = Scramble Spirits (W)
      - 009 = Jumbo Ozaki Super Masters Golf (W)
      [EDIT]
      31/07/2108: Added 2 pics to show how pins must be aligned on the motherboard and romboard and how to plug the floppy emulator
      [EDIT 2]
      Dynamic Country Club is now also available from the romboard for those not having a floppy drive controller (altough repro is available from @Mitsurugi-w) or wanting to cut loading times.
      [EDIT 3]
      A custom romboard can now be ordered with the kit for those not having an original romboard or as an upgrade.
      Looking for:
      - Sega Mega-CD 1 power board
      The post was edited 42 times, last by Apocalypse ().
    • Thanks guys :thumbsup:
      rewrite wrote:
      twistedsymphony wrote:
      RIP System 24 prices :D
      What prices? Couldn't find any for sale anyway!
      Darksoft wrote:
      Me neither :(
      Don't be mingy:
      ebay.fr/itm/Gain-Ground-Arcade…cbb6ab:g:aEAAAOSwlZtay3X1
      ebay.fr/itm/Gain-Ground-Arcade…2dda9b:g:6ZMAAOSwqVBZYnPe
      :D
      Looking for:
    • That's good for my advertising "Play all those extremely expensive games for a tiny little small fraction of the price!" :D :D :D
      This brings the question, as romboard based games can still be found for a reasonable price from time to time (sometimes as low as $100), is it worth reproducing the floppy controller? I've built the part list, it should cost ~$50 in parts for one board plus PCBs cost. But it has to be reproduced first with a CAD tool...
      If you add labour on top of that to build the controller that's probably a "retail" price of $100 at the end.
      How do you feel about that guys?
      Looking for:
    • Given the fact that it will allow you to play all these extra games:
      I think it's worth it.
    • Definitely worth the effort and cost to build the controller. I will definitely get a full kit if you make them :thumbsup:
      I know I got 2 system 24 boards somewhere, 1 is either crack down or bonanza bros with the floppy drive, the other is a rom board game, forget which one.
      And to think I was planning to sell them off, I guess its good to hold onto certain things :)
      Found: Garegga, Bakraid, Gunnail, Hyper Duel
      Wanted: PCBs - Batsugun, Rapid Hero, Air Gallet Arts/Pop/Manuals - Garegga, Bakraid
      Vewlix CP Shipping Brackets (2x red sets preferred)
      Would it be possible to build a single board that replaces both the ROM board and the Floppy controller?
      The original floppy setup is pretty messy, I know I'd be willing to pay more for something that was more streamlined/self-contained.
      Projects: instagram | blog
      Wanted | For Sale/Trade
      I've spent a lot of time trying to reproduce the security chip located on the romboard in order to be able to design a completely new one.
      I've been able to reproduce the banking mechanism but for some reason some other needed signals never worked... I guess if this Altera chip was ever dumped I could merge my designs and make a "all-in-one" board (romboard + floppy controller + analog I/O board).
      But then final price would be probably close to $300.
      Let's say the actual design of the kit is V1, there might be a V2, maybe not.
      Looking for:
