Capcom 85H001 sound module reproduction
    • Capcom 85H001 sound module reproduction
      It's a replacement module I designed to replace the original one used on the following Capcom boards:
      - Ghosts'n Goblins/Makaimura
      - Avengers
      - Legendary Wings/Aresu no tsubasa
      - Section Z
      - Trojan/Tatakai no banka
      - Gun Smoke
      - Black Tiger/Black Dragon
      I know of 3 different types (there might be more) which are interchangeable between games:
      - Ceramic module without any marking: seen on Makaimura first run for instance
      - Plastic module ref. 85H001 5I
      - Plastic module ref. 85H001 5H
      I don't have much time at the moment so I plan to sell bare PCBs for now.
      Needed parts:
      - 2 rows of 30 male header pins
      - 1 * Z80 CPU (DIP40)
      - 1* 6116 type RAM (DIP24, narrow 0.3" package)
      - 1 * 74LS08 (DIP14)
      - 1 * 74LS21 (DIP14)
      - 2 * 74LS74 (DIP14)
      - 2 * 74LS138 (DIP16)
      - 1 * 74LS139 (DIP16)
      - 1 * 74LS174 (DIP16)
      - 1 * 74LS367 (DIP16)
      - 27 * 10kΩ resistor (1/8, 1/6 or 1/4W are fine)
      - 11 * 100nF capacitor
      First solder header pins:
      IC layout: BE CAREFUL ONE OF THE LS138 HAS TO BE REVERSE MOUNTED
      Capacitors:
      Resistors have to be mounted vertically:
      Module fits in place of the original one, I advise to install a socket. It must be installed so references of ICs on the replacement module are legible the same way ICs on the board:
      Quick video of the module tested on Trojan:
      Quick video of the module tested on Ghosts'n Goblins:
      Bare PCBs are now for sale $18 shipped worldwide in an envelope.
      Looking for:
      The post was edited 14 times, last by Apocalypse ().
    • Bare PCBs are now for sale $18 shipped worldwide in an envelope.
      Looking for:
    • Most games use a Z80 @ 3 or 4Mhz so Z80A or Z80B are a safe bet.
      Looking for:
