There is no such thing. the NAOMI is a JVS board which means that a JVS IO board is needed for the controls.I just haven't found any harnesses that would connect to the naomi straight up?
What connection do you have going to this board? Do you need 600-7143-004 and 005?To me a truly great feature of the Naomi hardware is the ability to output both 15khz and 31khz video modes.
Now being an owner of a Blast City of course OP you'll want to use 31khz (aka VGA)...
But if you had a older non-tri-sync monitor cab (lets say Super Neo Candy just for reference) you could set the Naomi to 15khz output, then run a "VGA" (quotes because its sending a composited sync on pin 13 only which isn't actually VGA spec at all) cable into the Sega IO (which will then feed this 15khz video via the JAMMA standard/harness).
Only connect this to the Naomi if you set 15khz mode output (and have a older CRT limiting you to 15khz only, as Naomi looks stunning in 31khz).
JAMMAWhat connection do you have going to this board?
That's Blast City specific parts/harnesses that I don't give a fuck about... Do you have a JAMMA harness? Yes or No?Do you need 600-7143-004 and 005?
I just got a capcom IO (coordinating a blast for myself) don't you need that to hook up to a Naomi?Don't get a Capcom IO if you have Blast. It's totally unnecessary.
Capcom IO is twice as expensive and supports a smaller list of games than the official Sega IO boards. the reason people use it is because it has a built in audio amplifier and 3.3V power converter which makes it easier to hook up to JAMMA cabs.I just got a capcom IO (coordinating a blast for myself) don't you need that to hook up to a Naomi?
