I have an Astro City cab in perfect working order, but it came with PSU 400-5198-01Y which does not boot the newer CAVE boards. So I found a new PSU (400-5198-01) and last week swapped it in. I first powered on the cab with no pcb and tested +5v at the jamma connector... it's 5.25 so I drop it to 5.10v, which is what I normally do. I then connect my test board (non CV1000) and power on the cab... looks/works/sounds perfect. Nice! Next I connect my Futari BL pcb and power it on, it's all good except there is this issue where pixels in the bottom left are failing to draw. It creates a small black moving line, I made a video to show it:
Next day I tested the FutariBL pcb in my other cab and it looks perfect, so the issue is not with the pcb (phew...). Anyone have insight as to what could be causing this? I'm not super hopeful it can be fixed, mainly just trying to determine if it's safe to run boards on that PSU.
Thx in advance for any info
