yoyoyou234
Hello everyone, I wonder if you know that there's a dev mode in cps3 games. In JOJOBA, in can be entered by changing region in emulators like FBA.
Here're the problems:
1. The game region and flags are controlled by a byte in bios, so which byte is the one that control the region in JOJOBA? It would be better if there's a region-changed rom to enter the dev mode available.
2. I want to burn a superbios on my CPS3 HW. Does other cps3 games have dev modes and how to enter them?
Darksoft released an iso converter tool several years ago that let you force a region.. but I think the download to it is dead.
Looks like you could modify country_offset in the source and add that the developer mode into it. But you might also just be able to modify the rom already on the multi iso, just need a way to get it to pass the crc check.
Modding ISO seems a little bit troublesome, and will cause CRC issue.
I wonder if one of the country codes can be modified to development code in Super BIOS bin file. Perhaps only need change few bytes in Hex editor. :rolleyes:
Any suggestion? @Darksoft
The BIOS itself doesnt have any check IIRC and the BIOS has been modified so that it accepts any CD regardless if it has wrong CRC.
