For those who have a cab and swap in jamma boards and cps2/Naomi other stuff with rca stereo output, what do you do for audio to make it easy? I’m assuming what I want is
Some sort of speaker to line level converter to take audio off the jamma edge. I guess get it to rca. I’ve seen two ways of wiring this. Using speaker+ And speaker- and using speaker+ and ground and not using the speaker-? This is confusing. I guess some sort of box that makes it simple and just gives speaker in and rca out would be ideal.
Then take that to a little speaker amp with rca inputs and stereo output. So I can just use a rca splitter to get jamma audio or plug in stereo from cps2/Naomi whatever bypassing the speaker to line level converter.
Then simple wire from the speaker amp to stereo cab speakers.
Maybe a rca switchbox to switch from jamma audio to whatever else and make that and the amp easily accessible to control bass, treble, volume levels.
Basically I want a solution that will work for everything and be easily adjustable and I’m wondering what you all do.
