Lindbergh IP Address
    • Lindbergh IP Address
      A few questions regarding the network settings of a Lindbergh:
      1) Where do you set the ip/gateway/dns etc? I'm specifically testing with Outrun 2 SP, but I can't find any network settings like the Chihiro has.
      2) There are 2 network LAN ports on the Lindbergh, one as part of the motherboard, the other on the JVS card. Am I right in assuming you would use the JVS port for linking multiple units together?
      Thanks!
    • New
      You need to go into the Test menu to set the IP/gateway/dns settings.
      Use the LAN port next to the Audio ports on the motherboard should be used for linked play not the one on the JVS card.
