SelfDeniedHoarderz
Melbourne
I have a B-board Super Street Fighter 2 that I would like to use as donor board for Darksoft Multi CPS2.
From what I can see on the mainboard: https://imgur.com/a/KyMK6d4
  • 93646B-4 (Revision 4)
  • PAL (BGSB3) ---> not even sure about this as I dont think it is F-Pal or G Pal.
I am just wondering if this board is compatible with Multi CPS2? If it is, would it be simple as replace the PAL chip with the G-Pal?
I'm pretty sure all the boards are compatible if they working.
I used a revision 3 board. You may just need to change a few jumpers, put a PAL-G chip in and install a jumper wire. You will also want to install the key writing wires.
Have you read and watched all the info yet?
http://www.saveyourgames.it/file/Instructions_CPS2_Multi_Boot_v3.1.pdf
If you go through this and get yourself familiar with the process it will make it much easier.
Yup, should work fine as long as you install a G PAL + jumper wire :)
You can order a G PAL together with the kit, otherwise there a quite a few people with a programmer who can set you up ;)
@xodaraP for example as you’re down under
