Hi, got a KI2 with ``disk error``. But when i check the HD at the menu, is says ``disk ok!``. The u98 is the 1.4 and it`s ok. Dunno what can i do more. Strangely, when i put in the ``burn-in test``, there`s a loop between ``test ok`` and a gray screen.
ki2 ``disk error``
Is it the original harddrive? I remember there was a hacked bios that was needed to use another drive.
it`s a CF card, not the original hd. Tested in a good pcb and worked. So i think it`s not the problem
The burn in test doesn't check the hard drive it tests RAM and I think CPU
Try replacing the CF card with another one and see if that helps, it may also be an issue with the adapter board
Have you replaced the U98 boot ROM with the AnyIDE version? -
where i can find the anyIDE version? maybe that`s the cause. But unfortunately, i will have to wait for my eprom eraser to answer this question =(
Did you install the CF card or did you buy it like that? Did you replace the boot ROM when the CF card was installed? If you bought the CF as a kit it will usually come with the replacement ROM
bought as a kit, but it didnt work. So i will exclude for sure that before moving to the pcb itself, cause i found the pcbs ``as is``.
Well,erased the u98 in both ki 1 and ki 2; programmed the anyIDE and the result is the same at ki1, the hd light doesnt go on, even with original hd; in ki2, the blue screen and the test sound are followed by a black screen.
Tested the new rom and the cf cards in a good ki1 board and it went everything ok. -
Show us a picture of the non-working KI2 pcb please.
You may be missing a small converter board.If you want to support me, sign up for Dropbox by using db.tt/05qkhkFLVC. This gets you and me an extra 500MB for hosting roms, or other arcade related files -
ibb.co/jHn7i9
ps - just pulled of the u98 for testing/programming -
It's a bit hard to see but that looks like a dedicated KI2. From the KI project website:
have multi: cps* ttx2 st-v gnet f3 mvs sega sys24/c2 sys2x6 naomi(netboot) m72
want multi: pgm sys16/18/32 m92 atomiswave seattle supernova jms32 naomi(cart) namco na-1/2 namco sys10/11/12
cabs: blast city x2, vewlix c
klov/vaps games list | custom fight sticks
current project(s): waiting on moar parts. organizing console stuff. -
Yes,its a dedicated one.my doubt now for the KI 2 is: the anyIDE u98 is used for both ki1 and ki2? Earlier, with another one, i was even getting into the test screen. But now i got just a black one.
Ps- hm, now i see there are different u98 for the dedicated and the converted pcb. Ill try the dedicated one . Maybe i bought the kit with the converted u98 one.The post was edited 1 time, last by TheBortot ().
if the drive is getting power and spinning up then check all the small inductors.
if none are open-circuit then you better hope it's a bad buffer chip.
btw, did you try a different ribbon cable? -
Yes, i tried :(.
Could well be the issue. KI1/KI2 conversion/KI2 Dedicated all have a different boot ROM - can you try the correct one and see if that helps? -
KI2 solved! many thanks to you guys. The rom within was the ``conversion`` one. So i changed to the dedicated.
Now the big problem with KI1: the ``disc active`` light doesn`t turn on, even with the original rom and HD. -
Share
- Facebook 0
- Twitter 0
- Google Plus 0
- Reddit 0
