Midway Quicksilver II PSU cap list
    • Midway Quicksilver II PSU cap list
      So the PSU in my other Hydro Thunder stopped working. Opening it up I noticed the caps had started to leak. I recapped it, but the damage was already done. I recapped the other one, which should hopefully keep it going for a while. It's a standard PC PSU, so shouldn't be too hard to replace. The specs are pretty beefy though.
      CWT-300ATX
      Input: 115V 7A / 230V 4A
      Output: DC 3.3V 14A, 5V 30A, 12V 8A, -5V 0.5A, -12V 0.5A, 5V SB 1.5A
      Main PCB:
      arcade-projects.com/forums/ind…5e412d7c650c40c35a245caa6
      Source Code
      1. Capacitor Qty Location Diameter
      2. 1uf 50V 4 C3, C4, C7, C102 5mm
      3. 2.2uf 50V 2 C5, C8 5mm
      4. 10uf 50V 1 C9 5mm
      5. 22uf 50V 1 C06 5mm
      6. 47uf 16V 1 C12 8mm
      7. 470uf 16V 1 C104 8mm
      8. 680uf 200V 2 C1, C2 25mm
      9. 1000uf 10V 1 C02 10mm
      10. 1000uf 16V 1 C13 10mm
      11. 1650uf 16V 1 C15 10mm
      12. 2200uf 10V 2 C16, C17 10mm
      Display All
      Sub PCB:
      Source Code
      2. 22uf 50V 1 C10 5mm
      3. 470uf 16V 2 C12, C13 8mm
