Killer Instinct pcb no sound
    • Killer Instinct pcb no sound
      So I have this KI board that I can’t get the sound to play. I thought maybe it was something wrong with the negatron so I tested it on my MK2 board and the sound worked fine. When I start up my KI board I don’t get a ding but a constant loud staticky buzz. I tried sound test and don’t get anything still the buzz throughout the whole time the game is running. Game starts up and plays fine. I attached a video of what I’m seeing and hearing does anyone think it may be the sound Roms or maybe need to get a new flash disk any help with this would be great. I really want to play this board but can’t bring myself to do it without any sound lol
    • GarouSP wrote:
      I could be wrong but I guess that this board needs -5v for sound.
      Hence the use of a negatron by OP.
      Looking for:
      - Sega System 18 romboard type 171-5987
    • GarouSP wrote:
      I don't understood what you meant to say.
      The OP is using a Power Source that does supply the -5v is what he means and yes that era of Midway pcbs required -5v, why the OP tested with a MKII to double check it wasn't the power supply being the issue.
      With KI boards I always check around the ROMs, ADSP-2105, and Pamp for cold solder joints. I also reseat everything as well that's socketed as these boards are pretty sensitive. That is where I always start. I don't think its the Flash as that only holds graphics if I recall, sound and program are on the ROMs.
      Q GrandAm 25 | MKII | JNX SuperGun | NEC XM29
      First Cab: Centipede (1987)
      Arcade Tech: 1994 - 2000
      The post was edited 2 times, last by ReplicaX: Added Flash line ().
      ROMs are bootstrap, sound and music. All program code is stored on the HDD/CF card
    • xodaraP wrote:
      ReplicaX wrote:
      The OP is using a Power Source that does supply the -5v is what he means and yes that era of Midway pcbs required -5v, why the OP tested with a MKII to double check it wasn't the power supply being the issue.With KI boards I always check around the ROMs, ADSP-2105, and Pamp for cold solder joints. I also reseat everything as well that's socketed as these boards are pretty sensitive. That is where I always start. I don't think its the Flash as that only holds graphics if I recall, sound and program are on the ROMs.
      I guess Midway was wrong
      Images
      No. U98 stores the bootstrap code so it is very much the "Game EPROM" - without that there's nothing to tell the board how to load the data from the HDD.
      Understood.
      OP: Also the audio section has work RAM as well and is known to go bad.
