The thickness is very close.@ReplicaX looks great! Where did you get it printed? Also is the material the same thickness as the original?
Factory Shipped on a 2L12B:I'm working on mine now. Was working great until I bumped the cab and the monitor died. Should be an easy fix though. Cold solder most likely.
Anyways, who knows what type of buttons and joys the cabs shipped with?
If you are referring to the Control Panel Overlay. Scroll up to post #64.Hi Guys is possible to have a stickers inlay file for control panel ?
regards
So I ordered the overlay from gameongrafix but didn’t specify the size. Consequently, the overlay I received was smaller than my control panel. The overlay I received measures Height: 9-11/16 Inches and Width: 24-3/4 Inches. What size control panel does everyone have? Mine measures 11” x 25”.The thickness is very close.@ReplicaX looks great! Where did you get it printed? Also is the material the same thickness as the original?
I used Scott at https://www.gameongrafix.com/
Sending an email now to give him permission to put it up on his website. He uses 3M /w Polycarb which I used on my first repro and it held up extremely well.
The CPO is 9.75" x 25". The CPO doesn't cover the entire front, that is intentional as the original doesn't either. It is a Reproduction for a reason, its the exact measurements of the original. Why GoG shorted you 1/4" is odd, but I always specify the size to them regardless, avoids confusion.So I ordered the overlay from gameongrafix but didn’t specify the size. Consequently, the overlay I received was smaller than my control panel. The overlay I received measures Height: 9-11/16 Inches and Width: 24-3/4 Inches. What size control panel does everyone have? Mine measures 11” x 25”.The thickness is very close.I used Scott at https://www.gameongrafix.com/@ReplicaX looks great! Where did you get it printed? Also is the material the same thickness as the original?
That’s odd I wonder what could have gone wrong. No worries I’m sure they’ll make things right for you.I didn’t apply the CPO yet. I currently have the Capcom diamond plate CPO on my panel that I got from GoG years ago.
I am in talks with Scott from GoG. I remeasured the length and it was 24-13/16; not quite 25” but I was more concerned about the height. My Q25 didn’t come with an original CPO so I didn’t have a reference. So if you’re saying that the original never wrapped around the bottom curve then it seems the CPO I received is pretty close to the measurements.
You have a full setup for Tournament Battle in Q25s?Considering this is about a capcom Q 25
Has anybody seen this top marquee of
super street fighter 2 tournament battle edition ?
that is the only piece missing for that same set up as pic,i could be wrong but i might be the only person out japan with this type of set up including all4 capcom Q25 cabs and game
Yes,just like picture avobeYou have a full setup for Tournament Battle in Q25s?Considering this is about a capcom Q 25
Are you using my reproduction overlay or do you have a SSFII one? I ask as many are looking for SSFII replacements.I’m in Los ángeles ca
i’m working on them at the moment by putting back 2player panels and new control panel overlays new sticks and buttons and put back a monitor that I pulled out to recapped
