Yes, slighty different pinoutyou’re talking about the pins right?also note there is a slight difference in the pinout of the 10p kick connector (japanese cabs) and 15p kick connector (UK cabs), sure you can find the difference via Google or on the Arcade Otaku Wiki
ah im sorta confused about what i should be looking for. the shape of the connector has 15 pins but a few are connected on the backYes, slighty different pinoutyou’re talking about the pins right?also note there is a slight difference in the pinout of the 10p kick connector (japanese cabs) and 15p kick connector (UK cabs), sure you can find the difference via Google or on the Arcade Otaku Wiki
could you take a look later at the two places i found people talking it if i left links here?Search for Naomi UK kickharness pinout, that is the 15pin.
The Japan cabs have the 10p pinout I shared earlier.
My work LAN block lots of pages like Arcade Otaku Wiki, so I cannot Google it for you
thanks sorry im probably just not getting it cause its latesure
as far as I know; yes!are astro/blast kick wiring the same as the naomi japan kick wiring?
should i buy the connector here? or do you know a better place to get it? maybe someone sells them with .110 quick disconnects https://www.amazon.com/dp/B006ZPH71Y/ref=cm_sw_r_cp_api_vq8FBb72NPJ2Zas far as I know; yes!are astro/blast kick wiring the same as the naomi japan kick wiring?
this is what i found when searching rs onlineI usually buy at RS online
They are AMP UP connectors
its pins 51-56 on the digital inputs on the jvs io board. they are outputs 1 through 6. do you know what those do?not from memory, would have to check my own cab...Where does it lead to?do you know what the 10 pin is?
does that mean its game specific
As far as I know it could be indeed.does that mean its game specific
i guess it might not be useful for me then. my cab isnt for racing. ill probably mostly use it for fighting gamesdoes that mean its game specificAs far as I know it could be indeed.Not sure which games/platforms use it in a normal Joystick cab.does that mean its game specific
Can image it being used in race cabs or something?
Maybe someone else know more details on these outputs?
so because im going to be adding more buttons, im going to have to get some of the wire terminals too. when i search for 175149 they have two listings. 175149-1 (pre tinned copper alloy) and 175149-2 (pre tinned brass). do you know which materials are used?check here for correct part numbers;
https://wiki.arcadeotaku.com/w/AMP_Universal_Power
You can also get them here (but much more expensive)
http://www.starcab.net/index.php?cPath=90_201
https://www.giz10p.co.uk/amp-up.html#
