mine has this going on
also note there is a slight difference in the pinout of the 10p kick connector (japanese cabs) and 15p kick connector (UK cabs), sure you can find the difference via Google or on the Arcade Otaku Wiki
you’re talking about the pins right?
Yes, slighty different pinout
ah im sorta confused about what i should be looking for. the shape of the connector has 15 pins but a few are connected on the back
Search for Naomi UK kickharness pinout, that is the 15pin.
The Japan cabs have the 10p pinout I shared earlier.
My work LAN block lots of pages like Arcade Otaku Wiki, so I cannot Google it for you ;)
could you take a look later at the two places i found people talking it if i left links here?
are astro/blast kick wiring the same as the naomi japan kick wiring?
not used in normal 'joystick' games, could be used for multiple things in dedicated cabs or something
does that mean its game specific
As far as I know it could be indeed.Not sure which games/platforms use it in a normal Joystick cab.
Can image it being used in race cabs or something?
Maybe someone else know more details on these outputs?
i guess it might not be useful for me then. my cab isnt for racing. ill probably mostly use it for fighting games
so because im going to be adding more buttons, im going to have to get some of the wire terminals too. when i search for 175149 they have two listings. 175149-1 (pre tinned copper alloy) and 175149-2 (pre tinned brass). do you know which materials are used?
http://www.te.com/commerce/Document...nglishENG_CD_175149_C2_175149-c.pdf175149-1
Shouldn’t matter in the end, original could be brass I think.
What’s the price difference?
