RGB via scart to consumer TV
    • RGB via scart to consumer TV
      Hi all,
      I've build a rig for my MVS and willing to connect it to a Sony consumer TV that supports RGB via scart.
      Do I need to place resistors or capacitors on the r,g,b and sync lines? What about power to switch the TV to RGB mode?
      Any diagrams (proven once, not from Google) will be appreciated :P
    • Hello.. I am not sure if you are saying that the Sony TV has RGB built in via scart or if you are looking to add RGB into the TV..
      The SHMUPS forum has a tread of Sony tv that can be RGB, not many TV and not much documentation since this is kind of new thing that people are looking into doing since any monitor that can do RGB cost an arm and a leg these days....at least in my area.
      The Future Is Now
    • You need to place resistors on the R/G/B lines and I also highly recommend a sync stripper/cleaner for the sync line.
      Something like the LM1881 is good for this, but I say do the full design with a low-pass filter/trap.
      Full
      Once built it looks something like this...
      Not this lazy/hacky mess...
      That uses this stripped down design (missing the low-pass filter)...
      Darksoft: CPS3, CPS2, F3, MVS
      RGB: RECO v2, HAS v3
      Frank_fjs: JAMMA Extender (HAS - Special Edition)
      HighFlow: Acrylic Cases (M72, TMNT, T-Unit, Y-Unit)
      The post was edited 2 times, last by jassin000 ().
    • Matan wrote:
      Hi all,
      What's the rig you've built?
      @Frank_fjs or @RGB are both Supergun builders who might be able to help out with video output info....
