Yes, I know I need to cut that trace, but it's alway beeping. I can't cut more than that, If I continue I will make a holeCut that trace
Seriously? more deeper?deeper
Of course, I always use a tester to verify, I make a cut and always verify , but it continue beeping after every cut.In my opinion cut and use a tester, il is not enough cut again
Usa un cutter, campeon!It's hard to express yourself when no dominates the language
You are absolutely right. There is thin trace that connet the pad. I tried to use the razor blade and cut it, then test it with multimeter however it's still shorted. Any tips on how to cut trace clean and nice?Cut that trace
¡Jajajaja! Sí, lo he entendidoUsa un cutter, campeon!Eso si que lo has entendido, eh??It's hard to express yourself when no dominates the language
I use either of these, depending on how big the cut needs to be;You are absolutely right. There is thin trace that connet the pad. I tried to use the razor blade and cut it, then test it with multimeter however it's still shorted. Any tips on how to cut trace clean and nice?Cut that trace
must say I find that surprising, I did it a few times and found it very easy to cut, just cut with a decent sharp knife like the ones I showed above and that's it.Gotta tell you guys that it was tough as to cut the trace. I cut it quite deep and it's still shorted. Only got 1 OPEN after half an hour.
Good PCB trace design i guess
I had the same issue. You need to remove the little plastic clip from one of the connectors, either by cutting with some flush cutters or wedging a flat head underneath and prying upwards.I can't close the lid
Done!I had the same issue. You need to remove the little plastic clip from one of the connectors, either by cutting with some flush cutters or wedging a flat head underneath and prying upwards.I can't close the lid
