rewrite and I are stumped as to what is causing this. I checked the ground from monitor to neck and its there.
Did the best i could but phone suck
just woke up ill try to get better video or picturesVery hard to see. I don't see jailbars at all.
i can't take anything better. But I can see them on right side of that video in middle.Very hard to see. I don't see jailbars at all.
It's.... not very good? It's a re-spriting of a Japanese game based on a manga IIRC. One of those "if you have nostalgia for it" kind of games tbh.I need to look into this.
I can clearly see them under capcom at least 3 darker colors areas.I see scanlines I don't see any jailbars?
Also, how the hell did I not know there is a Ghostbusters arcade game. I need to look into this.
I have a computer but no vga port or adapter or a cord. I'm not sure changing colors would cause jailbars to go away. They are still there in colored scenes just not as visable.Can you display some different solid color screens with a PC or other device?
That would quickly rule out burn-in if the jail bar effect disappears when changing sources.
I've personally dealt with KC twice, first time (Vewlix Capcom) everything was perfect.If it is kc really fucked me.
I absolutely love your attitude.It's very rare to find a machine that is perfect.
And you know what ? It doesn't matter because it's part of the charm of arcade.
Arcade is a quest, you can't just buy the perfect cabinet in one shot, you will constatly tinker it.
Thank you. I could not remember it.1. Ghostbusters is a reskinning of Meikyu Hunter G.
OMG you are the anti-Jassin!And you know what ? It doesn't matter because it's part of the charm of arcade.
Huh, I just don't understand it.I absolutely love your attitude.
the convergence was way worse. I spent 6 hours trying to get it better. Its still off on all 4 sides but I am out of strips and it way better. I gotta get more strips but I am out and I can't find anymore.1. Ghostbusters is a reskinning of Meikyu Hunter G.
2. Are you talking about the purple spots on the white background? Have you deguassed the monitor?
3. The convergence on that tube is off slightly in the lower right. I'm thinking in the transit from CA to HI, maybe the purity and convergence rings moved a bit. Purity would give you those discolored blotches. Are all of the wedges still in place on the yoke and is the screw holding the rings tight?
iv already bought a new cp from no that was restored. Its getting delivered today. 2 new marquee holders a new psu for backup.Another good news, you can still spot another screen, another chassis or whatever part misses you if you feel you need to upgrade, it's just a matter of patience.
Arcade is a quest, you can't just buy the perfect cabinet in one shot, you will constatly tinker it, spot spare parts, fix things. (Yes parts are very old they can die on you at any time so be aware and prepared for that)
