It's magic, you know, never believe it's not soInstallation video (I apologize for the terrible picture quality. I'm new to editing and I think I just processed it wrong):
-ud
We should conclude that you need to rewatch the first example It is shorted in video for first example: Rev.6/7 and all-in-one Black.Looks like you left the 'Open for Rev5' jumper open for all board revisions. Question:
- With the exception of Rev 5 boards, if we short this jumper, does the 5V get drawn correctly to the InfiniKey?
- Or do we still need to run wire for 5v and Gnd?
- Or should we conclude that the 'Open for Rev 5' is a misprint and can be ignored in all instances.
- Then proceed to wire 5v & Gnd as you've shown?
Indeed. I guess an all 0xFF key in the device would have helped in this scenario, but I guess it's too late for that! Regardless, resoldering the jumpers on the InfiniKey-CPS2 isn't all that different to removing it.Just remove. It's not hard. Just get a blob of solder moving back and forth across the header.
-ud
Actually all jumpers open == all 0xFF key But I still don't recommend running InfiniKey paired with DS Multi because if user is key writing with their Multi, on power-up there could be contention on the key writing signals. Best to just avoid that scenario all together.Indeed. I guess an all 0xFF key in the device would have helped in this scenario, but I guess it's too late for that! Regardless, resoldering the jumpers on the InfiniKey-CPS2 isn't all that different to removing it.Just remove. It's not hard. Just get a blob of solder moving back and forth across the header.
-ud
Man, my mind is on the turkey already.We should conclude that you need to rewatch the first example It is shorted in video for first example: Rev.6/7 and all-in-one Black.
Exactly same as photos in OP.
-ud
When they are available.When do I pay you for them?
That's this thread: UD-USB DecodersHi Undamed
I would like to purchase 3 of your USB to DB15 Joystick Adapter
Do you have any Estimate on when it will be available again ?
Where can I buy it ?
