zerox_dogma
Hi, the infinikey works with any games regions boards??
Asia region for example
Thanks
Thanks
Thanks! I need install it for two asian gamesThe region doesn't matter, the only thing that matters is the revision of the gameboard - you can see all the details in the YT video in the first post of this thread for the details.
I have notified them, so whenever they are ready to order more, I've got them.Looks like Paradise is out of stock in the US - they didn't have an ETA on a restock.
Anyone in the US have an extra they'd sell? I'd also be down to do a bulk buy directly if you have any in stock, @undamned
I'd be down with splitting some with you man, if you help me install them!Looks like Paradise is out of stock in the US - they didn't have an ETA on a restock.
Yeah of course, I like direct, but he said he'd only do batches of 10, I'm not sure I need 10, but maybe I just need to get more PCBs until I do...Just get them direct from @undamned get of them. You can easily sell what you don’t use or just keep the. While you get more boards.
Which version PCB?I have an infinikey'd cps2 b board still shows a green screen. Any ideas? This is the 6th installation of infinikey for me and the 5 before ran well first attempt (thanks to UD's design) so I dont think it's an installation issue. I reflowed the solder 3 or 4 times over last few months.
reflow that joints and use there some flux first and then put fresh solder over. No good joints there sadly... the solder should look shinny .Its a rev 7. Xvsj.
https://imgur.com/a/ExpJVNA
The soldering looks bad but checked that the infinikey has proper connection with the board.
Look here buddyOkies desolder and try again. What happens if the solder is shiny btw?
Jumper "4" solder blob looks suspect.The soldering looks bad but checked that the infinikey has proper connection with the board.
Patience, sir Was that you that wrote looking also for CPS1 InfiniKey? If so, that is the reason for delay.I need buy some infinikeys but are out stock.
Where I can buy 5 infinikey . I wrote undamned but never received answers.
