I recall @electric_monk saying he was going to design an enclosure for it so I didn't bother.@twistedsymphony what about 3d printed tray with usb access hole in the front panel ?
Nope.does it make tekken 4 compatible with system 256 ?
Seems like the best thing would be to accommodate a RPi as well and an LCD screen for game selection where the DVD drive normally sits, would be really sweet to have a fully integrated solution that works with @brizzos multi dongle and can write both that and the disc image at the same time as @twistedsymphony envisioned.@electric_monk - I will look forward to your new enclosure that hopefully makes it fit in the dvd rom space - also closing that gap will bring airflow back to what it should be....
I tried printing your original - and although it printer perfectly - I couldn't actually get it to fit right or snap together...
Thanks!
Matt
AFAIK, no.Is there any documentation except this page ?
They're not jumpers, it's the audio output connector for discs that use Red Book Audio the plastic cap that's on there is just there to keep the pins from shorting out on stuff.What are the jumper used for ?
not currently, but maybe in a future firmware update.is it possible to put a an HDD game on the SD card
Oops, I didn't know for the audio outputThey're not jumpers, it's the audio output connector for discs that use Red Book Audio the plastic cap that's on there is just there to keep the pins from shorting out on stuff.What are the jumper used for ?not currently, but maybe in a future firmware update.is it possible to put a an HDD game on the SD card
