kioku25
Germany
Could someone help me out with the pinout for the Sega LCA-60027 wiring harness, that allows JVS boards to be powered by the Lindy's PSU? Haven't had much luck finding someone who'd be willing to part with his, so I'm having to resort to building my own.
the main power connector on a Lindbergh PSU is ATX just like a PC... so any ATX to JVS adapter should work. Also the pinout for that and other connectors should be right on the label for the PSU.
I was hoping to have both JVS and Lindy connected at the same time, since that PSU has three atx connectors, one with 14 pins, one with 20 pins and one with 24 pins. From the looks of it, the LCA-60027 is going to occupy the 14 and 20 pin connectors, leaving the 24 pin for the Lindy.
I will have a look at the label once the PSU gets here.
Think you're right about that, as per @kioku25 googling:
"The technique is commonly used in low-voltage power supplies, where it is called remote sensing, to measure the voltage delivered to the load independent of the voltage drop in the supply wires."
