codecrank
so officially there's only 2 panels for the swing, a 2L6B and a 4L12B , which is ok for most beat em ups, but not optimal for many games. :(
Panel 1 - 3L12B
since the game was actually in use in an arcade, I couldn't take the panel home to trace it, I had to rely on art I found , and scale that according to some measurements I took on site. A buddy laser cut a piece of wood so I could check the most crucial part: the carriage bolt holes. Seemed good to go.
an order from the sheet metal shop later... mounting studs , and a little paint...
well that's a bit boring, so a little inkscape later, let's apply some artwork, :D
and the part everyone hates, but can be almost... zen like ... wiring
at that point I still wasn't 100% sure that everything would line up perfectly.. but it did :thumbsup:
And there you have it, time for some Night Slashers action, with plenty of elbow room, just in time for halloween :D
I can probably put it on a flatbed scanner and set you scan, with a couple key measurements. you should be able to get it replicated with that.
Whatever you can do brother, would be much appreciated. :)
Lovely panel. I made a 4l12b repro using ooyk's art and arcadeartshop for printing.. but the colour is slightly off on mine (a little too dark). Yours looks spot on.
There was an official 3l9b panel - a guy on neoarcadia has one : https://goo.gl/images/Rrx6au I'd buy an alberto1225 repro (and yours!) for sure. I'll keep an eye out for those. I used his stick mounting brackets on my panel and they're excellent.
