I would like to be added to the list as well!
Let's find where in the chain there is an issue - do you get an image from the GBS-8220 when plugged into a monitor directly? Furthermore, is this with GBS-control, or the stock firmware? The GBS-8xxx series is not known for great compatibility or performance when stock, so it would be good to determine if that is working correctly first.
Second, does your capture device not accept 15KHz RGB directly? If you have not tried, it might be worth giving it a shot.
I was a able to get an image from the GBS to a monitor directly
This was done with stock firmware, and has been working for me for a while now.
Here is how it looked on stream before hand with the stock GBS-8220
( http://www.twitch.tv/dabsandcabs/v/687079659?sr=a&t=1s )
I am also using this capture device
(https://www.amazon.com/dp/B00PC5HUA6/ref=cm_sw_r_cp_apa_i_krngFbGSZ4APX )
Sup man I checked out your stream and it was really cool with you running original hardware.
oh snap, thanks man!
still fixing a lot of stuff on how it looks and getting more stream equipment, like a mic and webcam stuff.
we are gonna stream again 25th/26th this September. few friends are coming over for some 3rd strike action!
I was a able to get an image from the GBS to a monitor directlyThis was done with stock firmware, and has been working for me for a while now.
Awesome brother I will be there to support if I am not out on mission.
Thx,
Kelly
Please add me to the list.
SPLITFIRE test video coming shortly. Got it in the mail two days ago. Awesome little device and amazing work from the guys up at NAC and Mike Moffitt.
Can't see it but your interference might be from not grounding the AC portion of your PSU earth ground. Leaving it floating can cause those types of issues.
Also give the VGA cable a check, maybe the grounding issues come from it.
Had this issue recently on another machine.
Thanks for your video. I can't wait to get mine.
My Jamma 2 Scart PCb is giving me a harde time. lately. :cursing:
Been held up because I have run out of the printed boxes. While those will be seeing a redesign in the future, I'm finishing off this batch with an order of that same type of box in order to move things along.
Great thanks for the update, appreciate it
What if we don't care about printed boxes? :)
I would like to be added to the list plox
The list is up to date on page 16.
If I can find out who got their last order I can eliminate quite a few names from the beginning.
It's getting buried in the page counts. Ill repost it soon
If people do not care about the print materials and are okay with just the unit, then I can finish out the current batch like that, and get the new (more compact) box design together afterwards. I would like for the next design to either be ready for mailing without an additional box, or to fit in a small flat rate box, to keep things smaller and cheaper.
