Outrun 2 SDX Wiring Diagram
    • Outrun 2 SDX Wiring Diagram
      Does anyone have a copy of the Outrun 2 SDX wiring diagram?
      This is the one with dual steering wheels.
      The Hummer Extreme MDX diagram would also work as its a very similar setup.
      Every PDF I have found for Outrun is badly scanned and you can't read the diagram.
      The Hummer ones don't include the diagram at all.
      Thanks,
      Matt.
    • New
      Specifically what are you needing to reference?
      Would it be significantly different than ID4? I can't recall if that one has a good wiring diagram.
      IIRC, when I briefly booted the Lindbergh versions, the controls worked on my original OR2SP (Chihiro version) cab, so if you're just after controls, that one might be good enough.
