glstar
Italy
Hi.
My friend got a strange problem with his Type X3 original with USF4.
This is the USF4 version that got 2players and offline from Nesica.
Now he got the error 0203 I/O INITIALISATION ERROR
We tried to dismount all but nothing change.
We also tried to change the JVS boards into the tx3 with another one from Puzzle & Dragons, but it gave boot error….
Someone know what the problem could be?
RFID reader connected to the JVS connection and controls via Fast IO (UTP type cable)?
Can you post a pic of your connections?
TTX3 requires Fast IO to work, so not sure how you have made the P&D to work?
Yes i know, but this version has been modded (don't know from who), for normal JVS connection.
I cannot manage to have it working in a P&D motherboard….
I tried to use internal JVS boards from a P&D, changing the security key with the USF4 one, but it gave me boot error, like the hdd wasn't recognized.
I'm not familiar with TX3 hardware, but it's possible that the hdd and security are also tied to the JVS IO board?(the one where the security key reside).
The connections are those with usb cable attached to the Fast io board.
HDD and dongle are tied to the bios/motherboard, you cannot swap those
never heard about TTX3 being modded for JVS, I would still say the Fast IO is missing.
Did you ever had this working before on JVS?
yes i know this, but also the PCI Express board where the dongle reside, it's also tied to the motherboard?
Yes of course.
Has worked fine for months….
Just few days ago stopped to works giving that error.
That motherboard works also into a Lindbergh cabinet using JVS.
Very cool that is possible!
Really wouldn’t know what is going on then :(
Does it still work in the Lindbergh or does that give a error as well?
I don't know.
I tried to swap the JVS boards with the P&D ones, but it won't start giving hdd error.
So i can't understand if the problem is something software or hardware.
TX3 originally should be connected using FAST I/O right?
The Fast I/O connection is done using a lan cable?
Correct, connection labeled FAST IO MAIN next to the JVS
But the strange thing than is that his Vewlix C only have this board inside
But to me seems that it only have the USB and not the Fast I/O connectors…..
Maybe i see it wrong.
So you have an original USF4 X3 that was modded to use JVS connection? It was working fine with the JVS connection?
No RFID card reader attached?
No Fast IO?
Now it wont work with any JVS IO?
The Vewlix C either came with a JVS io or a Fast IO & RFID Card Reader.
No Fast IO?
My friend bought an original USF4 complete kit.
The game was modded to have two players, offline and jvs.
He had this connected via usb from around a year now but some days ago he got this error.
RFID is the card reader?
If so, yes he have it, but it was working also without it.
No Fast I/O, he Always had it connected via usb.
Now it won't work in the vewlix and into the Lindbergh cabinet.
He just told me that some minutes ago he dismount all (ram, vga, jvs boards etc...) then reattach them and the board booted again (this on the Lindbergh cabinet).
Then he detach it and put it back into the Vewlix and now the same error….0203...also on the Lindbergh...again….
Really a strange behaviour
So it is working now after he reconnected everything?
ah…….so in teory he shouldn't be able to play TX3 stuff inside it, right?
He can, but either the X3 game supports the JVS connection or fast io, so therefore the Vewlix needs to also have either jvs or fast io.
Have your friend reach out to who did the mod for him. I forget what the 0203 error means, I should write these things down :)
Have worked one time on the Lindbergh cabinet, then he disconnect it from the Lindbergh to put it back in the Vewlix and now it doesn't work anymore, in both cabinet...
