Are these still available to order? Would like to get a blue one.
CPS-2 Custom Metal Case -Pre-Orders open now
Gah, finally trying to install this... My Noctua fan is 3 pin and the CPS2 fan is 2 pin. I thought I remembered there being a way to fix it somewhere in this thread but I can't find it. Anyone able to help?
i can't look without opening it up comletely, , but i think i just connected it so that only red and black on the noctua were connected - i didn't even change the connector if i remember correctly - yellow should be the wire for speed control.Darksoft: CPS2, MVS, Taito F3, Sega ST-V
Apocalypse: Irem M72
RGB: HAS 3.1
Frank_fjs: Sentinel Supergun, 4xMD2NEO (2 old, 2 new), 2xSNES2NEO, Jamma Extender w. Kick extension
XianXi: Spitfire
Cab: Sega Blast City (2930)
VAPS
Words to live by -
Yup I did the same as the above. The clearance to put the case back is scary though, it barely fits :pMulti Systems: Sega STV + DS Multi | CPS2 + DS Multi | CPS3 + DS Multi | Taito F3 + DS Multi | MVS + DS Multi | Naomi 2 + Pi Netboot | Atomiswave | Taito G-Net + 2011 Bios | Taito TypeX2 + Niko Multi | M72 + Apo Multi
Cabs: Tecmo Kyotaro | Tekken 5 NNC -
You guys are very correct, I did the same. Oh GOD the clearance is tight reassembling it. But now? They're both cased and waiting for the CPS1 multi and case, then I get to play Jenga putting those 3 and a switcher into my big blue.
Also, the LCD fit just fine in my CPS2 case. -
By the way, i really do not know how i will fix the LCD fitting problem.
Myabe i will ask to people the LCD measurements that have cps2 multi kit. -
One thing I did notice though, 2 of the standoffs for the motherboard didn't line up right with mine. I'm not super concerned, 6 should be enough, but it was kinda weird.
hursit wrote:
Yeah ,there is only 2-3mm space between Fan and the mainboard as the original. It isBy the way, i really do not know how i will fix the LCD fitting problem.
hursit wrote:
KalessinDB wrote:
hursit wrote:
I need the New LCD measurements.
@Takosuke and @KingSopz , if you have Measurements device, please give me the detailed measurements
With this device
i don't own one of those devices but i think i got it for you its 2 3/4 inches which is 2.75 inches and in MM its 69.85mmThanks
KingSopz -
I have 7cm for the lengthMulti Systems: Sega STV + DS Multi | CPS2 + DS Multi | CPS3 + DS Multi | Taito F3 + DS Multi | MVS + DS Multi | Naomi 2 + Pi Netboot | Atomiswave | Taito G-Net + 2011 Bios | Taito TypeX2 + Niko Multi | M72 + Apo Multi
I have the same LCD issue and have not assembled yet. Has anyone done so? Curious of the tools that were used. My thought is a dremel...not sure what bit though.
Happy to send the measurement of my screen as well. I have a laser measurement device that might work. -
Finally ready to assemble this case and I have a question about the test button connections. My understanding is the signal wires can be soldered wherever on the button. Where is a proper spot for the ground wire?
Also +1 for the LCD not fitting correctly but sounds like I can fix that with a dremel or something similar so I'm not too worried. -
Are you thinking of making a Naomi case?Thanks
KingSopz -
Now we need the cps1 case
and the multi of course
Share
- Facebook 0
- Twitter 0
- Google Plus 0
- Reddit 0
Users Online 1
1 Guest
Similar Threads
