TMF68k
JAPAN
A power failure occurred while updating the firmware. The menu does not start. Can I initialize it? Please help me.
Hi tmf, if you put again the menu files and firmware properly you should be able to update it well
Mr BIG
I tried with some boards but it is impossible.
It does not start. Is it an initial malfunction? I bought two.Another cartridge is okay.
</s></s></s></s></s></s></s></s>
Try with another SD card, put the firmware in the update folder and the menu files too
Mr BIG
Give up. Where can I get the repair?
Let it sit at cross hatch screen for a lil while it should switch to a different screen also swapp out to a good and card those you pictured are not great make sure you format ti fat32
I worked hard, but this cartridge does not work.
Another cartridge has no problem.
so you got one of the cartridges to fully work and the other one doesn’t work at all swap the Sd card of the one working
I went on a long repair trip.
The returned repair works perfectly.
Thank you.
Thank you for your advice.
I didn't think I could meet @Darksoft in Spain.thanks
