Stunnaman33
New User
What wattage power supply do you recommend for the Parsec?
Button 5 is used by Atomiswave. Pretty small market I'd say.The v2.1 Parsec will definitely have the now standard connector and pinout for the kick harness. Why I didn't switch over earlier, I'm not sure.
I don't think the jumpers to switch button 5 and coin on the controller port were used by many people, so I might as well remove that. Originally I thought it would be good for Neo Geo controllers and adapters to give access to button 5, but it's another thing I now think is unnecessary.
I originally thought a standby led (lights when ATX power supply is powered) was nice to have, but that's another thing I don't think anybody will miss.
I'm trying to simplify the assembly and (slightly) reduce the parts count, but I don't want to remove any useful features in the process.
There was originally a dipswitch jumper that swapped Coin and Button 5, that is what he is talking about removing. I don't think he means Button 5 would go away, but IMO I'd hope that it would remain for Atomiswave use.Button 5 is used by Atomiswave. Pretty small market I'd say.
Ok, ThanksI sell the Parsec directly and through www.tindie.com
I have 1 left in stock at the moment.
Typically I build 6-8 Parsecs at a time and list them for sale. The next batch of 6-8 should be available late January.
if you look 5 posts above your post there are the changes from 2.0 to the latest 2.1.Somebody its selling 2.0 version
Its the same thing? I only want see my arcade boards , mvs and CPS2 games in my tv via OSSC without burning my ossc and my boards
Thanks @PascalP I’m veryyyy noob in this thingsif you look 5 posts above your post there are the changes from 2.0 to the latest 2.1.So it is up to you if the 2.0 will do or you need the 2.1Somebody its selling 2.0 version
Thanks so much for your response! Good to know about the way grounding works for control panels/joysticks and the Parsec HAT board too. Since I'll be using a SCART input on my OSSC which doesn't handle sound apparently, if I get a Q-Sound based CPS1 or 2 game, I could actually plug in its RCA jacks directly into the OSSC's stereo minijack audio input 1 with a stereo Y-cable (RCA to minijack); I didn't know before that these boards have RCA sound output jacks right on them. Looks like the CPS 1.5 boards handle stereo with RCA audio outputs too! These are the CPS 1 with Q-Sound PCB sets, e.g. The Punisher, Cadillacs & Dinosaurs, and Warriors of Fate—awesome games, btw. I didn't see RCA jacks in the pic below in the 2nd article, although I found my answer on eBay looking up The Punisher (see below).Stereo sound through the JAMMA connector is supported and can be selected with the stereo/mono switch. This is limited to early versions of the Neo Geo MVS arcade board (I'm not aware of any exceptions but maybe someone can correct me.)
Stereo sound coming from an auxiliary header CAN be connected using the deluxe hat board I offer as an add-on.
The deluxe hat board has a 1/8" stereo audio connector that's wired to the 8p mini-DIN A/V output connector of the Parsec. Using the auxiliary audio option requires a 1/8" audio plug be inserted into the "audio line out" connector on the Parsec main board to disable JAMMA audio. Sorry if this sounds complicated, I hope I'm explaining ok.
This feature basically lets you combine stereo audio from an auxiliary source to your RGB SCART connector.
A separate ground wire is not necessary when using the kick harness. All of an arcade game's button inputs are pulled low by connecting them to ground, and the Arcade game's ground is shared with the Parsec (through the JAMMA connection.)
