Raph_friend
I tried this method but it only shows 32MB, I probably got damaged memories.
I did check, but everything is ok.make sure the normal flash next to the original reverse flash do not have any solder bridge on them
No.and pairing them Pair 1 + Pair 3 or 4 ? would it work ?
Yes, there are up to 4 versions of possible SIMMS depending on the flashes installed: Fujitsu, Hitachi, Intel/Sharp and Macronix. Each chip has it's own protocol to write it, therefore the differences. The most usual, though are the Fujitsu.the 32MB board version shown is not the same as the 128mb... and both chip are on the same side of the board... are they 2 versions ?
I dont recall there being any difference.Is there a difference between MBM29F016-90PFTR and MBM29F016A-90PFTR Version ?
