Cabinet Crossbeats Rev Sunrise Nu 1.1 Questions
    • Cabinet Crossbeats Rev Sunrise Nu 1.1 Questions
      New
      Hey Guys, couple question,
      I recently finished restoring CrossxBeats machine (More like cleaning up and re-doing the speaker wiring and small solder fixes here and there), on the NU 1.1, I noticed there was a 64GB Commercial SATA and 500GB HDD (i'm guessing it's for all the songs etc), does anyone know of Nu's Security check for serial # or model # of the ssd/hdd , I want to do a backup each into same sized SSD and keep the original drives safe.
      Another thing, for anyone with the crossxbeats machine, I'm noticing if I do test for speakers, the top speakers are barely audible, I'm not sure if that's normal or not, i tested the amp and speaker to be working (hooked it up directly to a music source and works good), as well as test stereo cable so it comes down to what I think might be either it's by design or something going on with AMO-14066 Board (Very bottom board on the cake far left with 5 Jacks ,which has Audio In, Main & Head Phone connected), can anyone with CrossXBeats machine run sound test and confirm for me that top speakers are supposed to work at much lower volume then main speakers and sub woofer?
      My Arcade Adventures
      CandyCab25 CPS2, CPS3, & Naomi NetDimm
      Vewlix L w/ Jamma Kit & Taito X2
    • New
      Actually figured out the top speaker issue, The game volume being set at lower then 40% or so seems to tone down the top speakers quite a lot more then the bottom main speakers. I've decided to get some stereo volume controller w/ mute button to control the speaker volumes from dials outside of cabinet that way i can set the game volume higher and just lower it with volume control independently. having mute button on the speakers would be nice to have for playing via Headsets.
      I ordered 512gb ssd and 120gb ssd to just try to see about security.
    • New
      Looks like it was bitlocker encryption. doing sector by sector clone worked fine.
      Setup of external volume controls for Main Speaker, Top Speaker and Subwoofer working as well. Setting the game volume to 80 then control the rest through the knobs.
      Also had chance to change out all the fan to arctic silent fans, and change out the main powersupply with a 80+ gold silent power supply. And re do the gunked stock Thermal paste
      All in all, it worked out perfectly.
      Test running for bit over half a day, cabinet still running cool and fans barely audible how i like it.
