Hello, I'm new to the forum (and fairly inexperienced when it comes to working on arcades, although I've had Super Guns and a few cabinets for many years, and know how to plug things in) so if I'm in the wrong place, please advise.
I'm looking to use a 2 to 1 JAMMA switcher to put two Capcom CPS1 boards (listed in the subject line) in my cabinet. Currently swapping the JAMMA and kick harnesses every time I want to change games. I've seen a bit about voltages, etc, but it seems that with these two games I should be ok. I could just use a little help on what I need to buy (and any suggestions on who would be the best to buy it from).
From what I've gathered, I essentially need one of the 2 to 1 JAMMA switchers (I've seen a few) and a Kick Harness "condenser" - I'm thinking this is just a non-powered Y cable (2 in, one out).
I will plug the JAMMA harness in the cabinet (which I believe one end goes to all the buttons, speakers, monitor, etc) into the output of the splitter, same with the kick harness in the output to the "condenser" (although I don't know if I will be plugging in or soldering), and then is there a standard pin-out JAMMA harness that I can buy two and use to connect each of the boards to the inputs on the 2-1 switcher?
Any direction is super helpful, and I feel certain the info is out there, but with all of the Arcade 1Up stuff and other Street Fighter related items, parsing the search results has not lead me to what I'm lookin for here.
Thank you,
Robby
Thank you,
Robby
