Icade Problem
VballHerk
Johnstown Pa
Ohhh mighty arcade wizards!
I've installed maybe 6 icades recently and haven't had any issues. Until this weekend.
I installed the board friday night and tried it out and it was working as it should. Saturday I moved the cabinet into the next room and tried it.
When it's booting it's going through a bunch of system checks instead of the typical 1-60 count it usually does. After it's done with the checks it boots into a checkered color settings screen. And no buttons will do anything. I tried another board I had on hand and it does the same thing. So it's gotta be something in the wire right? Anyone have any ideas?
Thanks in advance!
SOLVED: I just wanted to make a solved reply in case anyone stumbles upon this post with a similar issue.
The test switch wire which I didn't have hooked up was getting pinch in a bunch of wires I had zip tied together. Pulled the wire out of the bunch and it's good to go again.
