wigsplitta
UK
I'm having issues getting my SuperBIOS cart(s) to work.
I've probably just forgotten to do something simple as I haven't played this for a couple of months, but when I try and load, all I get is a blank/black screen screen.
I've got the following HW : Standard, unmodified dead 2I cart | SuperBIOS cart from Joerg | SuperBIOS cart from mitsurugi-w (both are just bios updates - they have the original custom SH2)
The 2I cart works fine when used with the 2 x disc version of 3rd Strike where SIMMs have to be removed/swapped etc...
However, when I plug in either of the SuperBIOS carts, all I get is a blank/black screen. I've tried various CDs, but they make no difference. Is there something else I should be doing? I've tried holding 1p start when booting, but still the same blank screen.
I also ran a SIMM check, and that shows they are all good (2 x 64 and 4 x 128)
Any suggestions?
95% chance you just have dirty carts or a dirty cart socket causing this error. You might as well pull your simms and clean them while you are at it.
Thanks mitsurugi-w
I gave both carts and all simms a good cleaning, but to no avail.
The only other thing I could think of changing was the cabinet! And it worked! :D
Swapped the board over to Astro City number 2, and it booted up fine. Truly bizarre. I can only imagine it wasn't getting quite enough juice from the first cab. Not sure why the 2I booted fine though. Oh well, who cares!
