Pinned A Freeware Taito TypeX2 Multigame.
    • JoeAwesome wrote:
      Sounds like the JVS I/O. Do you know which is in it? Pull up the spec menu in the game select menu.
      It's a custom GFI (the makers of the G-Balance) I/O, as the G-Balance has both JVS and Jamma built in.
      At this stage I'm almost 100% certain it's an i/o issue, and possibly damage to the card rather than just a compatibility issue (though, porque no los dos?). While testing yesterday, the "P1 Left"-input randomly stopped doing anything in some of the games that were working, which makes me think the card itself has had a boo-boo.
      I'm going to buy a male-male USB-A cable today, just in case it's the cable or the USB-B connector, but other than that, it looks like I might have to get a new card.
      I have very little knowledge about JVS-cards, so I would very much appreciate any tips on what to get. I do NOT need JAMMA out, there are easier ways for me to play my older cards, and as the G-Balance is in the house, I was going to use it mainly for guests and kids who mostly go for the TTX2 beat-em-ups anyway.
      Any ideas?
      Any ideas?
      arcade-projects.com/forums/ind…ega-i-o-type-on-pictures/
      You can probably refer to this, so that you can see what other JVS I/Os are available, and are I guess you can say compatible with your set up. This helped me identify quite a lot of things, so hope this helps ya out
    • Excellent, thank you so much!
      Based on that I'll order a Sega 1.5 (as I found one v cheap and it should fulfil my needs, and if it doesn't that should work in my Net City as a backup). Looking at the different i/o boards, I notice that the Sega 3.0 seems to have the actual serial port that the G-Balance uses to connect to Jamma. Anyone know if this is correct? Or should I have gone for a Taito JVS (perhaps a K91X1097C, the one that came with the Vewlix - the G-Balance is very much a Vewlix-alike)?
      The post was edited 2 times, last by Urabutbl ().
    • I’m not familiar with the wiring of the G-Balance, but don’t go off the eye-test automatically with harnesses just because it looks like the serial ports match.
      Niko has made recommendations to Sega I/Os in this thread (though I can’t remember which, exactly), and I’ve used my V1 I/O that came with NAOMI Universal without issue. That’s not to say Taito’s or anyone else’s isn’t recommended, but make sure it matches the pinout if you’re using the existing wiring in a cab.
      Pass me the mustard! I just bought a car!
      The Sega Type 3's are quite good. Avoid the Taito JVS I/O boards.
      Want to show your support for the Freeware Taito TypeX2 Multi Project?: Buy Niko a Beer! :thumbsup:
      Official Freeware Taito TypeX2 Multi Thread
      Official Freeware Ringedge2 Multi Info ( PM me )
      Any ideas?
      I have the same JVS I/O with no problem (TXX/TTX2/...) GFI GL0801 ver 2.0 board (don't know for mame)
      @Niko How to use Video Preview ? dimensions codec folder ...
      I tried mp4 videos in the same place as the picture
      Settings Videos preview on
      Thanks
      Sega Naomi 1 (Tate) & Naomi 2 (Yoko) - NetBoot
      SNK MVS MV1F
      Sega ST-V Multi Darksoft
      Taito Type X Multi / X2 Multi
      Namco System 256
      The post was edited 4 times, last by Morzana ().
    • Hi,
      I gave a try using AM with 2.0 image.
      When launching the AM, everything is fine, I can launch any game I have, then when exiting the game (either with the 2.0 exit mechanism or through the test menu) and coming back to the AM, it is now in low resolution.
      Did anyone experienced the same issue?, Found any fix or workarounds?
      Thanks.
      Post by newprider ().
      This post was deleted by Darksoft ().
    • Mackie wrote:
      Hi,
      Thanks.
      I switched from 1.4 with AM to 2.0 without but will be tinkering tomorrow with it to hopefully create an 2.0 with AM. Did you do something special or just used the same AM that worked with 1.4?
      Will let you know if it switches to a low resolution.
      Sega Naomi Universal (NNC legs) with Taito Type X2 and a Sega Naomi
      Sega Astro City with Pandora and a NeoGeo MV-1C
      Arcade files mirror: arcade.pwn3d.io
    • New
      RHvdW wrote:
      Mackie wrote:
      Hi,
      Thanks.
      I just used the AM I had on my 1.4 image and deployed it on my 2.0 one.
      Looking forward to hear your feedback. I may have missed an option or a setting.
