That is the Fast IO, TAITO make a very similar one for JVS.You mean one like this here? What do you mean by HAS?
Any info on how to discern between the two versions?Watch out for CAPCOM IO, there are two versions and one does not work very well with TAITO. X and X2.
I would track down a TAITO JVS with a JAMMA edge and connect a HAS.
This is the JVS version:Any info on how to discern between the two versions?Watch out for CAPCOM IO, there are two versions and one does not work very well with TAITO. X and X2.
Ah, sorry, I meant how to discern between the two versions of the Capcom IO.This is the JVS version:Any info on how to discern between the two versions?Watch out for CAPCOM IO, there are two versions and one does not work very well with TAITO. X and X2.
https://wiki.arcadeotaku.com/w/JVS#Taito_JVS-AMP_PCB_Ver2.00
Hi, i have exact the same Problem....I tested this weekend the games nesica, I have 20 that works well including blazblue and persona. on the other hand I block on crimzon error nesys !!! and ikaruga who stays on the loading page of the game !!! someone managed to make them work
Yea I never knew that... I'm not sure what version I've got, going to check when I get back home.interesting with the two versions of the capcom IO
Look at the pictures here:Ah, sorry, I meant how to discern between the two versions of the Capcom IO.
Hello. I have not found the solution yetHi, i have exact the same Problem....does someone know how to fix that issue?I tested this weekend the games nesica, I have 20 that works well including blazblue and persona. on the other hand I block on crimzon error nesys !!! and ikaruga who stays on the loading page of the game !!! someone managed to make them work
Gonna quote myself.Nesice stuff is officially not supported as long as Taito keeps operating it, so don’t expect a straight forward out of the box solution...
So if something isn't working, its bot because it isn't "supported" its purely because your doing something worng.atrfate said:"support" and something working, are completely different concepts
Support means he would hand it to you on a silver platter, with tools, but if you take it into your own hands you can run them all on an x2 x3 whatever you want beacuse at the end of the day they are pc games with a system that is a pc. using the pre existing tools and software you could easily make anything run.
Hell ima update this with a crazy concept,
you can just plug a fast io in a pc install the driver, and then them with no emulation directly on the pc 2
or you can install a jvs com device on your pc and do the other, shocking.
And that worked just fine. Just need to build a kickharness from I/O to my supergun for the 6th buton.The cheap Sega jamma I/O is fine. Hook up the video and audio directly to the X2.
