CPS2 I/O Interface is a simple adapter that plugs in directly to the CPS2 motherboard and allows you to power the CPS2 using a standard ATX power supply, and to connect the NeoGeo compatible controllers. The CPS2 I/O interface is designed to be used with the
Features:
- ATX power supply connector with on/off switch
- Alternative 6pin VH power supply connector to connect a real arcade power supply (it's compatible with the HAS power harness)
- DB15 controller ports (NeoGeo compatible, extended to support buttons 5 and 6; compatible with the UD-USB adapter, which I strongly recommend to buy)
- Test, Service and Volume UP/DOWN buttons (Volume UP/DOWN buttons are needed to control the CPS2 digital AV interface)
- Buttons 1-4 on the JAMMA connector (button 4 can be disabled using a switch; it's necessary to disable button 4 for certain fighting games)
- Buttons 4-6 on the “kick harness” connector (it's compatible with the HAS kick harness)
The PCB project with the list of parts is available for free here.
I will also start selling fully assembled adapters soon (the PCB colour will be black, not purple as in the photos). The price is estimated at ~€40.
Pre-order yours here
Product page
More pictures:
