IGS PGM Custom Graphics PCB testers
    • Fluffy wrote:
      I'm going with "mounting hole diameter 0.91mm" from digikey.co.uk/product-detail/e…-27-10-0/ED5036-ND/158198
      The hole size I actually set in the PCB is 0.95mm, to account for a bit of shrinkage of the hole diameter from the copper hole plating, and production tolerances.
      You're the first one to try this with these boards, so it'll be interesting to see how this will work.
      Dont mind being a beta tester :D , gonna order a set of the 0548 which have 1.47mm diameter heads and some of the 3016 which have 1.22mm diameter heads, all the other specs are the same, mounting hole diameter is 0.91mm, etc... and see which have the better fitment, etc.. Thanks again for doing these :thumbsup:
      Wanted: PCBs - Batsugun, Battle Garegga, Battle Bakraid
      Other stuff - 19" Monitor/chassis and/or WG K7000 Chassis
      Vewlix Shipping Brackets (2x sets of the red ones would be nice)
      High End Headphones/Desktop Headphone Amps/DACs as well.
      If you have any of these for sale/trade let me know :thumbup:
    • @Fluffy PM when you can how much $$ to send your way for the new pcbs :)
    • Derick2k wrote:
      Awesome! Gonna order the pins.You are going with 0548s correct?
      Group buy ?
      Looking for:
      - faulty Hang-On, Space Harrier or Enduro Racer (2203 sound board)
      - Sega Mega-CD 1 power board
    • Apocalypse wrote:
      Group buy ?
      was just gonna order like 2,000 of these I think the price goes down to like 8-9 cents each, gonna see if price goes down if I get like 5K-10K. If anyone else wants some, I could try to do a group buy for these.
      Depending on what price we could negociate I'd keen for 3-5k.
      Looking for:
    • Derick2k wrote:
      Apocalypse wrote:
      Group buy ?
      I don't need those kinds of numbers, but I would be in for enough to cover a few boards. . .
      ok, Ill look into an order of lets say 10K :)
    • Fluffy wrote:
      Can you do me a favour and send me a few if you get them? I'll send them back together with your boards once I've got them.
      Yes I can, you want enough for a boardset, I estimated about 425 a set, for the main EPROMs.
    • Fluffy wrote:
      A handful to check hole diameter and spacing for a single EPROM should be enough.
      Ok, will send some your way. PM your address when you get a moment.
    • @Fluffy Got some of the pins in, will send out some your way tomorrow. These things are tiny.
    • @Derick2k 's pins arrived today, and I tried them out:
      First of all, the pins fit fine into the holes, though it is a bit fiddly putting them in.
      Aligning all pins of an EPROM was a bit tedious, I had to use magnification and a small jeweller's screwdriver. I've got recycled EPROMS with slightly bent legs, so if you have fresh new-old-stock it may be easier.
      The EPROM doesn't sit flush with the PCB, there is still quite a gap, though a lot less than a socket.
      This hole is one of the mounting posts, and it sits flush with the PCB. So spacing looks ok.
      Unfortunately I don't have a transparent shell available, so I can only check with the caliper relative to the mounting post. There should be a small air gap above the EPROM.
      For the initial installation it may be a good idea to first put the pins onto the pins of an EPROM, then fitting it into the PCB. That may be a lot quicker then installing the pins and then trying to insert the EPROM.
      It is probably not a solution for quick changes, but to have a chance to replace faulty EPROMs without desoldering.
      Side by side: MilMax, normal socket, normal socket + EPROM
      Edit: And I just noticed that I lost the silkscreen changes when I updated the footprints. #@$%
      The post was edited 2 times, last by Fluffy ().
    • can you put the sockets onto the legs before hand and then seat the whole thing in for soldering? might make alignment issues less pronounced?
      Woodies: Xevious, Pac-Man, Centipede, Dig Dug, Donkey Kong, Joust Cocktail, Space Invaders, Initial D3 Single, Mortal Kombat II, Zaxxon, Galaga, Space Shuttle Pinball
      Candies: 2x Aero City, New Astro City, 2x Blast City, Net City
      Other: Wacky Gator, Shoot the Moon, Movie Stop, Premier Crane
      VAPS
    • Frank_fjs wrote:
      Yep, as mentioned by fluffy at the end of post.
      ah yes... i should read all the way until the end before commenting! :whistling:
      VAPS
    • Looks awesome, looks like the EPROMs are soldered in. Milmax does sell these in dip carriers flex 32-42pins that you can basically push in all at once and solder in place, but it doesn’t help with the eprom legs alignment. I’m still gonna use these to get the supported games into original shells I have. Still deciding between the solid or transparent, think I’m going transparent to show off fluffys boards though.
