nam9
Norway
Hi.
I have an issue with a Sega Jamma JVS I/O. This one:
I am using it in conjunction with a TTX.
Problem is that P1 Button 2&3 are shorting. Each individual press on each gives simultaneous input on both.
I have checked continuity at the jamma edge (none), and followed each input trace through to the microcontroller (also good).
I have tested with two different joysticks and with JP1 in both A&B positions. No change.
Is it screwed? Is the microcontroller replaceable?
Anything else I should check?
Thanks in advance...
I had the same problem last week but it was coming from the amp connectors, have you checked everything on this side ?
...which are the amp connectors and what was the issue on yours?
Are they the surface mount PC2-24 in the above pic?
those which connect from the panel to the io board.
EDIT : OK You have a jamma type io board, so not the same case
