Cyber Trooper: Virtual On (Model 2) Wiring Schematic?
    • Cyber Trooper: Virtual On (Model 2) Wiring Schematic?
      By chance does anyone have this wiring schematic that is actually readable? I would be very appreciative.
      Tagging the VO master @twistedsymphony
      Thanks!
      -Drey
      -My Stuff-
      Namco cab (Namco System 246)
      Atomiswave (Ranger Mission)
      Atomiswave (Naomi 2 Multi)
      Area 51 (Dedicated)
      Sega Blast City
      Chewlix x2 *Working on modding*
      Area 51 *Converting to a Sharpshooter .. eventually*
      Korean Crowin 302 (empty) * who needs some parts?*
      Sega Showcase cab *For sale just not sure what I want yet*
    • -the wiring in the coin-box for the sound pots. Does not match the Daytona manuals I have,and I also have 3 wires dangling. Need to know for sure where they go.
      -Whoever had it prior to me getting it .. before the guy I got it from did a hack job on the video cables. I need to get it sorted and get them ready for LCD monitors.
      -I want to do a general wire verification prior to attempting to fire it up again to make sure I don't damage or burn anything out.
      I plan on trading the cab to @PlayYing and I don't want to trade him a hacked up cab that is not useable to him.
      -My Stuff-
      Area 51 (Dedicated)
      Sega Blast City
    • Even just a really clear picture will work.
      You are the man!
      -My Stuff-
      Area 51 (Dedicated)
      Sega Blast City
    • So I've discovered that the print quality of the original Diagram is barely legible garbage. it looks almost like for the USA manual they just threw a crappy copy of the JP manual schematic in there or something.
      600DPI and all you can really see are sharper blobs: filedropper.com/votwinwiringdiagram
      Projects: instagram | blog
      Wanted | For Sale/Trade
    • Ok i appreciate it. I will take a gander at it tomorrow. Thanks!
      -My Stuff-
      Area 51 (Dedicated)
      Sega Blast City
    • @twistedsymphony
      -Yeah that helps a good bit. Hard to read the monitor section. I get the RGB with ground and sync .. but for the power there are four other wires going to the monitor (aside from the green ground to the frame) I know two are line and neutral, but what is the other two for? I am not hooking the CRT monitors back up but I am curious. I will be crimping in new connectors as I don't want 120vac wires flopping around inside the cab.
      -I think I got the sound straightened out. One of the players sound pots was completely missing so I soldered a new one in. Matching the colors on the sound pot that was there.
      -There was a broken red wire on the coinbox harness. Not sure where it went but I reconnected it.
      -I need to properly tap into the 12vdc off the power supply to power the CRT to VGA converters. I only have one converter right now but I am hoping to get around to testing it tonight. I don't want to power it up until I know there's no random bare wires grounding out to anything.
      -My Stuff-
      Area 51 (Dedicated)
      Sega Blast City
    • nem wrote:
      The other pair of wires is for the degaussing circuit.
      OK cool .. a way to manually kick in degaussing if it the monitor doesn't do it at start up .. or if you don't want to restart the machine. Makes sense.
      -My Stuff-
      Area 51 (Dedicated)
      Sega Blast City
