I picked up a pair of Vewlix-F's from a group order over on ArcadeOtaku One has been cleaned and is in use (with a slight screen issue) and is working fine with Niko's TTX2-Multi nestled inside.
The second one needs some TLC (and now I've had time to strip it down some parts).
Every cab I buy I dismantle, clean and re-assemble for three specific reasons:-
So today I've gone from this....
To this....
And this....
And found these loose inside the cab....
I've now got several hours with a hoover, Kitchen surface wipes, magic eraser, hot soapy water ahead of me while I clean everything and re-assemble it...
I've documented the disassembly process and will add it to the thread once I've got it cleaned, as the wife is at work and the plastics are on the kitchen work surfaces and I need them gone by the time she gets home or I'm a dead-man.
- Second-hand Japanese cabs stink and are usually pretty dirty (unless your supplier has serviced them first).
- I get to check all the electrics are safe and if anything needs repairing/replacing.
- You always find something inside a used cab (best for me was £50 worth of change jammed in the back of a Sega Megalo, and 1/2 Oz of weed found in the cash box of a bootleg Galaxians woodie I bought from a dodgy part of Nottingham).
To this....
And this....
