http://imgbox.com/gPWxLsQ6which TOP file are you using? Go to menu and tell me the info that shows the About section.
Are you using the Smokemonster roll up pack for the games?Greetings everyone. I have had a Darksoft Neo Geo cartridge for nearly a week, and have just been approved for this site.
I wonder if someone can help me, as I have not been able to set it up properly at all. I have been following the firmware/menu and rom threads, and tried 8 times to set up as advised but every time I am getting 'no games' when booting up.
Is there a specific order to add these in or have I missed a step?
I am unfortunately not very good at all with emulation or rom software, and haven't a clue what to do from this point. It has been quite frustrating, and I would appreciate any extra guidance.
AES Darksoft - bought a card from the store. Used two different ones that are appropriate.
Yes. But I am unsure if I am setting this up appropriately? I have tried to do it exactly as specified, but it does not seem to work. Apologies, I'm not very good with things like this.Are you using the Smokemonster roll up pack for the games?
Have them at the root of the SD card in 'games' folder, make sure your SD is formatted in fat32.Yes. But I am unsure if I am setting this up appropriately? I have tried to do it exactly as specified, but it does not seem to work. Apologies, I'm not very good with things like this.
SD is formatted to fat32. By root to you mean the first folder? I have done this also.Have them at the root of the SD card in 'games' folder, make sure your SD is formatted in fat32.Yes. But I am unsure if I am setting this up appropriately? I have tried to do it exactly as specified, but it does not seem to work. Apologies, I'm not very good with things like this.Are you using the Smokemonster roll up pack for the games?
Memory card brand and size?SD is formatted to fat32. By root to you mean the first folder? I have done this also.
Transcend 16gb and Sandisk 16GBMemory card brand and size?SD is formatted to fat32. By root to you mean the first folder? I have done this also.
I Could be wrong but seems you have a problem with bank switching on slot 1, I would send it back for testing if I were you.Hello everyone,
I just uploaded some videos about my problems with the Darksoft multi AES
https://youtu.be/Gqn5lDfFYrU
https://youtu.be/V-3AqNO6WSE
https://youtu.be/Z2-LyHS7iIQ
https://youtu.be/mVpJBSIb-R4
https://youtu.be/RnwIR1KNz2Q
https://youtu.be/pWftWJ5wCbA
https://youtu.be/fWdlBIphY7U
https://youtu.be/mtfQyzVV-mo
https://youtu.be/0XAAEyZsMN8
https://youtu.be/E4REuVy03EQ
https://youtu.be/7HX7sBWicoo
The first videos shown my issues with FW_966 when I am trying to change the game on slot one.
the rest of the videos showing the last FW and menu loading games and especially game changing issue
Please if you have any suggestion, share it with me
Did you read the instructions?I wonder if someone can help me, as I have not been able to set it up properly at all. I have been following the firmware/menu and rom threads, and tried 8 times to set up as advised but every time I am getting 'no games' when booting up.
Yeah I did, and the updates disappeared from the SD card etc, I'll have another look when I get my AES back, as i sent it off for a recap and RGB bypass.Did you read the instructions?I wonder if someone can help me, as I have not been able to set it up properly at all. I have been following the firmware/menu and rom threads, and tried 8 times to set up as advised but every time I am getting 'no games' when booting up.
If you can't set it up after resding them, you can send it to me and I'll have a look.
@BRAKKUS1 the same for you.
I won't be able to have a look until July 19th, so if you send it this week I'll be able to have a look when I receive it.
Thank you Darksoft, It is strange sometimes games can be loaded sometimes not. In one of the video I could load Samurai spirit but one week before I could not but blazing star yes.@raffy92 I doubt that your cart is faulty and most probably is a problem with your PSU. Maybe I'm wrong, so I'm offering you the option to send it to me so I can have a look. If you are concerned about shipping costs, maybe some user here that is buying anything from Japan, or sending to Europe, could include your cart.
Thanks.
