[Repaired] Captain America and the Avengers Repair Log
    • [Repaired] Captain America and the Avengers Repair Log
      I thought it was time for me to try repairing boards. I probably don’t have much of a knowledge about it outside of reading a bunch of logs, nor do I have half of the equipment, but we all have to start somewhere! The plan is to build both up as I go.
      Writing this here will help me to stay accountable and hopefully receive some tips and advice :)
      So got this Captain America and the Avengers from Data East for a low enough price, disclosed as booting but with issues, mostly sound.
      It came in full of dust, and dead flies/cobwebs/egg sacks. Yikes. I brushed most of it off and will definitely Simple Green and wash it as soon as possible. This is after brushing it X(
      I noticed already some dirt and corrosion that I will have to look into once cleaned up
      Booted it to do an initial check, and almost no image with a big loud buzz.
      Pushing gently a bit on the EPROMs randomly managed to get me an image and eliminate the buzz! But the colors are wonky (missing).
      Sometimes, the image gets garbled and pressing a bit on the board fixes it
      Adding a credit to leave the attract mode, the sound plays good, music and SFX!
      It seems like the debug is enabled though, and I will have to lookup the dip switch settings.
      At least the game is alive and responsive. The fact that I can have sound, image and controls seems to be a good thing.
      Next step will be to remove all the chips, give it a good cleaning overall, clean the sockets and legs and do a visual inspection to see all that can potentially be broken (traces, legs, etc).
      To be continued!
      Multi Systems: Sega STV + DS Multi | CPS2 + DS Multi | CPS3 + DS Multi | Taito F3 + DS Multi | MVS + DS Multi | Naomi 2 + Pi Netboot | Atomiswave | Taito G-Net + 2011 Bios | Taito TypeX2 + Niko Multi | M72 + Apo Multi
      Cabs: Tecmo Kyotaro | Tekken 5 NNC
      The post was edited 1 time, last by Takosuke ().
    • Next step was to remove all the chips for a deep cleaning.
      It was even nastier underneath:
      After using a nice paint brush to remove most of the dead insect parts and spider egg sacks, I prayed the entire board (both sides) abundantly with Simple Green.
      Rinced it slowly in the sink after letting the Simple Green rest for a minute or two, then removed more stuck dead insect parts and did the same process once more for good measure.
      I let it drain and dry a little bit, and then used my ESD protected Air Duster to push the excess water out of the sockets and help the drying process (now more than a minute or two at a time).
      I let the board rest for a day and a night in the nice hot Californian weather, using the Air Duster a few more times once in a while.
      Next step was to do a full visual inspection of the board.
      • Nothing major detected, no lifter legs on the legs of the chips, but a few scratches on the traces.
      • Used the multimeter to check continuity and all seemed fine.
      Before doing more tests, I proceeded to cleaning the EPROMs and Pals.
      • One of the EPROMs had a bent leg that I managed to carefully salvage while cleaning it.
      • For the rest, I used a nail filer to carefully clean all the dirt off from the legs.
      • I then re-seated all of the chips in their sockets to do a quick test:
      Colors are back, screen is stable for the Attract mode!
      I let it run for a while and all good!
      Starting the game gives me still that debug code :/
      But pressing start on player two made it disappear!!
      Played the game for about 25 minutes with no issue!
      • Image good, controls good, sound perfect.
      Success! It was an easy one!
