Frank_fjs wrote:
I've not tested with this particular item however can tell you that the Top3000 does indeed program Atmel chips and is able to set fuse bits.
Personally I use my Mini Pro to program Atmel chips and specify fuse settings, works great and it opens INO files fine. Again, I've not tested with this adapter as I'm still awaiting PCBs to arrive.
My chosen USB ISP software is unable to read INO files and requires HEX or BIN files otherwise I'd have used it with my ISP programmer.
Multi's: CPS2 / Taito F3 / Irem M72
Superguns : HAS v3.1
Scart switch : Gscartsw V5.2
JNX: Spitfire
NAC: Splitfire
My Arcade Stuff
![[dreamcast_ss]](https://www.arcade-projects.com/forums/wcf/images/smilies/gaming/dreamcast_ss.png)
JNX: Spitfire
NAC: Splitfire
My Arcade Stuff
![[nes-101]](https://www.arcade-projects.com/forums/wcf/images/smilies/gaming/nes-101.png)
![[pce]](https://www.arcade-projects.com/forums/wcf/images/smilies/gaming/pce.png)
![[genesis]](https://www.arcade-projects.com/forums/wcf/images/smilies/gaming/genesis.png)
![[segacd]](https://www.arcade-projects.com/forums/wcf/images/smilies/gaming/segacd.png)
![[neogeo]](https://www.arcade-projects.com/forums/wcf/images/smilies/gaming/neogeo.gif)
![[snes]](https://www.arcade-projects.com/forums/wcf/images/smilies/gaming/snes.png)
![[saturn]](https://www.arcade-projects.com/forums/wcf/images/smilies/gaming/saturn.png)
![[psx]](https://www.arcade-projects.com/forums/wcf/images/smilies/gaming/psx.png)
![[n64]](https://www.arcade-projects.com/forums/wcf/images/smilies/gaming/n64.png)
![[gamecube]](https://www.arcade-projects.com/forums/wcf/images/smilies/gaming/gamecube.png)
