worked allllll night to get it done. (1:40am here)
I really wanted to ship it by tomorrow
you guys waited so long, and i dont know how long the shipping will be
just got an adaptor for a Mr.do a few days ago....took 3 months to get here...
*sigh*
anyway now its my turn to wait for the best part.
When you'll all be showing it off
(i always get a nice warm feeling inside huhu)
ok for the new people buying for the first time.
i'll explain it here. ( i had a nice page printed to explain how to install the case and its stuck on my unreachable PC back at work)
You'll get a pack of screws inside box.
-Black ones (x5) are for holding the case and base together. (Youll need a small hexagonal head)
-screws with a white plastic washer (6x) are to be put in each pcb's holes
-Plastic washers (6x +1extra)are to be put on the other side of the pcb on each screws. that way pcb is held between a pair of plastic washers.
they can be tricky to install on screws...so just insert them on the screw and twist them clockwise until its fit to the pcb.
when all six are done... put the pcb right on top of the base's inserts and screw each one halfway, so that the pcb slowly move down equally.
and finally all the way down
Now this part is for every TMNT cases.
The konami Logo sticker is free and not glued to the case. so you can put it where you want !
Its vynil so there's some trick to apply them
-get a spray bottle and put some dishes soap inside ( just a few)
-spray the part you want to put the sticker on.
-put the sticker on the soapy water you sprayed and adjust it.
When its ready , you'll have remove the water beneath... back then i was using an old credit card with something smooth around it,
and you do multiple passes on the sticker to remove bubbles and wrinkles.
surely some videos on youtube. if you are more visual.
and im off to bed ... =_=
