Yes, Im in, dont know for what but we doing this :D Will PM you back.
ill be around at work for 3-4 hours.
-Got some old designs to update like sexy parodius,
-take notes on the inventory here,
-order whatever i need for the upcoming order.
so ill be around if you have last minutes questions.
I'll make a new plate for @asra just to make sure his selector can fits
since i dont own one here. (hole in the middle will be quite larger)
also noticed a small conflict between middle plate and Frank_FJS selector when a cable is plugged in for the controller.
depending of cable it might get pushed down while closing the case and its not a good thing.
Ill give the case a small heigh boost +.150" on each sides should be more then enough
ok back to work ! :D
time to make magic
Almost everyone has paid up :)
(still no words from @trmm .)
If by monday i get every payments, im starting this up next week.
if i wait too much it might get longer to have them done.
Update time!
Quite unexpected but making one sega16 case was ok with our machine but with so many, air vents for front case caused crashes with pieces flipping all over on the alum. Sheet.
Lucky for me, i manage to have enough material left to start over and correct the problems :) BUT
that means that on a new next order ill have to calcul a new price sadly. Should be 5usd more. (More time to detach everything) Dont worry everyone this is not affecting current order :)
In the end, step one is done.
-laser
-inserts
-bendings
-coating
-vinyl install
-shipping
order #3 Update time :)
things are going very well !
-laser
-bendings
-inserts (currently working on)
-coating
-vinyl install
-shipping
that thing is going to be quite a monster
but everyone here is freaking amazed lol
can't wait to see it once paint coated.
Wow! Looks awesome. Is that Aluminum or SS? If aluminum, I wonder how it would look anodized in some colors? But if anodized , it would not hold up like the powdercoat would. Regardless, case looks amazing. Makes me wish I had an MK pcb.
I could do SS, but cost/weight would be quite another kind of story.
I prefer alu. Very light, nice coating quality. This one is diferent, i really wanted to make something special.
Ill try to hook the pcb in tonight to see if everything is correctly aligned. If everything good, next week i should have the coating done and ready for stickers.
Yuuuup it has a few things to make better and 1 hole on a plate completely off...
But DAMN. it install perfectly.
Cant do much about cables poping outside near jamma plug (for now)
All that is missing is the black color and vinyl.
All cases are also in the painting section.
tabarnak !!!
Very very pretty. Have you considered, rather than doing 2 separate pieces, planning to use https://bit-district.com/arcade/midway/mortal-kombat-2-pcb-consolidation-kit.html to make it a single stack?
I'm likely to buy the case either way, but I DO have the consolidation kit installed and it's quite nice.
the version i got have a staked pcb already on it. i see there's some kinf of trick you can do to get rid of it.
But i wanted to make a way for anyone to just get everything inside :)
and the best part...is yet to come !
eye of the dragon is perfectly align with red led on sound board XD that will be so freaking awesome when its powered on
tabarnak !!!
Indeed, friend ;)
