EverythingWhiffs
I had a problem very similar to the one in this thread except it happened after switching from one ROM set to another and now I can't seem to fix it.
I just got the multikit yesterday from Paradise Arcade, set up the hardware as specified in the guide by Mitsurugi-W by using my dead MvC1 board and upon trying to run the new roll-up pack I was greeted with the LCD acting normally but nothing displaying on my CRT. after doing some troubleshooting I found out I would either have to solder to the small pads for the 4-wire setup or I would have to run the old ROM roll-up. After some frustration and no success with getting a good enough join I decided to un-solder the wires from the Darksoft board and use the old set of ROMs. After i loaded them to my SD card I started getting the message "LCD init" when trying to boot, I googled that tried what was in the previously linked thread, and still got the error. As far as I've been told, you shouldn't have to solder for the old roll-up, but I figured if I had to I would just try again with the 4-wire setup, the problem being when I switched back to the new roll-up, I was still getting the error on the LCD. That's where I currently stand on my situation and I was working on this from when I got home from work at 10:45ish last night to about 5:30 in the morning.
If I made any apparent mistakes, please feel free to educate me on how to fix it. If you need some pictures of the board I will have to provide them later tonight after work.
