JohnRambo'sKnife
Awesome. Do you have a design up that could be printed by Oshpark?
I'm not sure what would be the best way to combine HSync+VSync into CSync, any suggestion? this would be useful for regenerating CSync too. Anyway you could do that with other circuit and plug the output into this circuit input.Great to see people are still improving this design @rsignal.
If you'd like to go for broke, do you think it would be possible to add the option to accept either CSync or H/VSync input to your model?
@rsignalAnd here is an update to the schematic to include H+V sync combiner on the unused gates on IC2
Yes, yes, fix v1 before adding features. (Credit philmurr, UKVAC)
Testing boards before releasing, and showing the schematics is the way to go, great job!Although I can share the gerbers with anyone interested (just send me a PM) I prefer to test before making them public.
After doing some tests with 74AHCT1G17 Schmitt buffer with mixed results (works fine with all boards tested except MVS) I've incorporated a 74HC14 buffer as RGB explains followed by a voltage divider in a similar way used in Tim Worthington's AV-Driver, but using common 470R and 75R resistors instead of 475R and 82.5R. This way TTL / 350mV CSYNC is selectable by a jumper.
Hello @pacoarcadeI've just compiled latest version (1.2.3) from new Kicad 6.0.6. Since I've not ordered this specific file please consider it experimental (it should work anyway).
I've made a small PCB with the trimpot to improve compatibility. Although the circuit is tested I've not ordered this one yet, but I can share gerbers for those interested.
Hi Robert. This is the schematic:hi
I want to make a sync pcb. can you help me? could you send me your wiring diagram?
thanks
