Universal monitor bracket for Vewlix - Compatibility list unfinished
    • Universal monitor bracket for Vewlix - Compatibility list unfinished
      Hi, I finally came up with a design that will fit just about any monitor into a vewlix. I had to scrap several designs since it wasn't good enough.
      Bracket plate (purple) will be installed on the monitor VESA mount and the main bracket (mint) will push down the monitor to the case. Cover (yellow) will be installed on top of the assembly. Purple plate can be relocated depending on the monitor VESA mount location.
      Click pictures to expand.
      Will work with any:
      Modern era monitor thickness – can't confirm your 10 year old TV will fit
      VESA mount location
      VESA style: 200 X 100 and 100 X 100
      Improvement over the last design:
      The old design had a minor issue where the glass will go in when corners are pushed from the outside. This happens when the monitor is “hanging” on the bracket instead of being pushing down to the case by the bracket. This was my pet peeve and hardest thing to solve in order to make the bracket universal. Some monitors don’t have a complete flat surface on the back that the existing design wasn’t ideal. The new design will ensure monitor will be well pushed down regardless of the monitor type.
      Compatibility:
      It is very haste to say which vewlix will definitely work. I want to be very careful about this since I don't want to spread the word and find out what I said was incorrect. I designed this based off of F after checking 20 F cabinets.
      I want to say old vewlix models such as F and L but even this needs to be physically verified. The vewlix model doesn’t dictates what monitor you have!! You have to physically pull out from the cab to check. For instance, my vewlix L came with a 1080P monitor P32L150 for whatever reason that the bracket won't work with this model. I'll be working with Cereth to build a data and compatibility list.
      What I can definitely tell is, this is not compatible with 1080P monitor in diamond and original monitor in Vewlix FC. Design will eventually follow up. I already have a rough design but I want to verify the current design before moving onto the next one.
      Price:
      I can’t say anything at this point since cost fluctuates by order quantity. Once the prototype is good I’ll get a quote and determine the best price per quantity. Then, I'll announce the price. I tried to simplify the design as much as possible reduce the manufacturing time.
      PS
      It is possible the design can be modified to work with Chewlix but this will require some inputs from Chewlix owners since there isn't any standardize design I can follow.
      Progress:
      1/13/20
      I'm getting 3 prototypes. Drawings have been sent to manufacturer. Two for me one for Cereth.
      Display Spoiler
      Update: 8/23/19
      Prototype bracket has arrived. Fit-check done. See #64
      Update: 8/6/19
      Designed a bracket so it can be used on L, L AMI, F and FC (or C) See #60
      Update: 7/20/19
      I've designed a bracket to secure the monitor inside the case. See #36
      Display Spoiler
      This is severely outdated. 1/13/20
      Hello, I’ve been looking into replacing outdated Vewlix Sanwa monitor to modern display. I’ve been brainstorming for a while and finally decided to do it. This is not a final version but to proof my concept. Any improvement and suggestion are welcome. I need suggestion on preventing the monitor from shifting inside the monitor frame. For now, I’ve used foam blocks. A temporary bandage patch.
      I used LG monitor 32MP58HQ. Any equivalent model will work. I was going try to use the LG monitor VESA mount but I had to remove the chassis due to clearance.
      The required modification will be extending the backlight and remote button harness. It’s not a common connector that I can recognize. The wire gauge felt like 26 or 28. You “can” screw down the video board like what I did (half-ass) and call it a day. However, I would strongly recommend securing down the board with your preference.
      Some small steps have been omitted for simplicity.
      Yes, what you see behind the glass is dirt that have been accumulated for a long time.
      1. Disassemble. Separate the glass vewlix monitor
      2. Remove all components on Vewlix chassis
      3. Tape down the glass on vewlix monitor frame
      4. Remove 3 screws behind U shape cover on LG monitor (missing photo)
      5. Disassemble LG monitor
      6. Carefully disconnect the LVDS ribbon and backlight harness.
      7. Remove LG monitor chassis
      8. Put disassembled LG monitor into vewlix monitor frame
      9. Put foams to prevent monitor shifting inside the frame
      10. Install vewlix chassis to frame
      11. Relocate the LG monitor video board onto vewlix chassis
      12. Put foam blocks between LG monitor and chassis - you want the foam to be just enough to push down the monitor.
      13. Connect all modified harness and HDMI cable and etc.
      14. Close cover (missing photo)
      No Taito original parts have been harmed :D
      arcade-projects.com/forums/ind…10b417744c980330512520695
      The post was edited 6 times, last by Hadouken Arcade ().
    • Thanks for posting this here! I heard about it from a buddy who saw it on Facebook — but I don’t visit Facebook often (ever). Glad to have it over here, and I’m definitely looking at doing this for my FC.
      multis: cps* ttx1/2 gnet f3 mvs sega st-v/16b/24/c2/naomi(netboot) sys2x6 m72
      projects: conversions, fixing Fighting Bujutsu
    • Thank you so much for this!
      The first of what I consider to actually be a proper Vewlix LCD replacement tutorial (because the screen isn't taped inside the Vewlix but properly mounted inside its enclosure).
      Darksoft: CPS3, CPS2, F3, MVS
      RGB: RECO v2, HAS v3
      invzim: Jammafier v1.6b
    • Hadouken Arcade wrote:
      radiantsvgun wrote:
      Looks good, id like to see how x2 or such would work. How do you make monitor adjustments?
      Simple. Just need to extend the harness and place where you desire. Brightness is also adjustable through windows and Mac application via HDMI. Monitor will turn on automatically when power is applied. No need to push ON.
      I am going to gamble and try this in my ami. Any recommendations on the tape and foam? Looks like I can get the lcd on amazon.
      I just used thin electrical tape from 3M. I have to find out what foam part number I'll be using since I used scrapped fire retardant foams from work. 1" height foam worked out well. I haven't shopped around but you can purchase from mcmaster(link). Does L AMI version has the chassis that I used? My vewlix L only has two brackets holding the assembly. Yes, availability was one factor that I chose this monitor.
    • Thanks for the post. I think Im going to try this. I have one question though. I noticed that the LG 32MP58HQ has a actual screen size of 31.5" not 32". Is the LG smaller than the original monitor? Im not home to check my vewlix so it may actually have a 31.5" screen also. I was just wondering if any of the new monitor frame was visible through the glass. Or if you only see the screen.
      I am not sure if it does, Ami can have a wei-ya or a tft. I ordered the lcd and some mounting tape, and I’m off this weekend so I will give it a try.
      Make sure to do a burn-in test before you start disassembling the monitor :D
      muell67 wrote:
      It looks like the LG 32MP58HQ is a older model would the LG 32ML600M-B be a better choice? Its only slightly more money.
      Not necessary old but different. It is using a panel with HDR. You can use concept that I did though. I chose 32MP58HQ because it has been manufactured for quite a while and available anywhere.
    • I would not personally put any panel in a cab without knowing exactly what the input lag was first. Something to keep in mind before you just grab any panel that fits. Being a 'newer' model doesn't mean it's better in that respect. The marketing page claims low lag for the LG 32ML600M-B but doesn't even list a spec (the grey to grey response they list isn't the same thing).
      displaylag.com/exposed-input-lag-vs-response-time/
      This is gonna be a personal preference thing, but for me anything that's not strictly sub frame lag from the center of the screen isn't acceptable for an arcade monitor.
      I hear you, I have a black diamond monitor in my blue diamond. If I can put this in my AMI successfully I will put the monitor through some tests- compare the two and see how it measures up.
    • I thought @Derick2k had measured the lag of the Sanwa Vewlix LCD next to the New New (aka Diamond Black) LCD.
      I can't seem to find that post atm so maybe he'll pop in and repost the results.
